4.10 Question!
Old Apr 24, 2003 | 01:24 AM
GpMike24's Avatar
Question 4.10 Question!
Straight up...are 4.10's worth the $$??? What will i get from them?
Old Apr 24, 2003 | 05:38 AM
Hyperspeed97z28's Avatar
one hell of a snotty ride! i herd on a stock car though they tend to now pull as hard in 5th
Old Apr 24, 2003 | 07:22 AM
smokin5s's Avatar
I have had it in my stock 10 bolt for quite a while..... with a 4.10, 1.6 rockers, and a cat-back exhast, I was able to pull a 108 trap speed.... that's running with LS1's...... plus the "cool" factor that now you can always chirp 3rd and sometimes just plain break it loose. I've heard that 4.10 greatly improve the wear on your stock 10 bolt.... depends on your mod list I guess. I have just about everything that you can do to a stock block done on mine (heads, CAM, N2O etc.....) so we'll see how well it holds up for me.
Old Apr 24, 2003 | 11:06 AM
norcalstreet's Avatar
I have used both 3.73 and 4.10 in an otherwise stock 10-bolt. The 4.10 is immensley fun to drive with but the 3.73 gives better gas mileage and a faster top speed. I preferred the 4.10 overall but it is a weaker gear and more prone to breaking under abuse.
Save your money and apply it to a 12-bolt with 4.10 gears.
Old Apr 24, 2003 | 01:04 PM
BUBBA's Avatar
With an M-6, I can't see going with 3.73s over the 4.10s. 4.10s make sense out of 6th and provide twice the torque increase that the 3.73s provide over 3.42s. JMHO
Old Apr 24, 2003 | 01:17 PM
SVT Killer LV's Avatar
I loved my 4.10's but i ran outta gear on the bottle.. NA.. 4.10's all the way...
Old Apr 24, 2003 | 01:20 PM
Grover's Avatar
Eddie,
Where were you shifting at on the bottle? I am getting ready to install a NX wet kit and already have 4.10's in my 12 bolt. I plan on shifting at 6500 and am hoping I won't run out of gear.
Old Apr 24, 2003 | 01:28 PM
smokin5s's Avatar
Originally posted by Grover
Eddie,
The CC 306 cam is a pretty high RPM cam... I also have that cam, and I am planning on shifting at arould 6750 on the bottle.....
Old Apr 24, 2003 | 01:34 PM
Eddie,
I was planning on shifting around 6700... If you wanna shoot the ****s.. IM me at BlackZ28ofDeath
Old Apr 24, 2003 | 01:36 PM
You should be cutting it damn close... I dropped to 3.73.. I will be 3.90 once the 9" goes in.. whenever that is
Old Apr 24, 2003 | 03:48 PM
Grover's Avatar
I am currently shifting at 6800 NA, but according to my dyno run there is no reason to shift above 6500. Maybe I will just have to run it up to 6800 on the juice to be able to live with the 4.10's.
Old Apr 24, 2003 | 04:19 PM
smokin5s's Avatar
From what I've read, the reason for shifting that high is because when you do shift, it puts you right in your sweet spot.
camy 1993
Feb 1, 2015 07:16 PM
Noer
Parts Wanted
Jan 19, 2015 10:19 AM
cmdeshon
Dec 27, 2014 10:06 AM
Like My Taillights?
Aug 27, 2002 09:16 PM
