4.10 gear installed...question
Old Jun 15, 2003 | 06:39 PM
Fastrthnu's Avatar
I just had the 4.10 gear put in my car, my first question is shouldn't the car be burning the darn tires off when I floor it...or am I wrong here? Not that I'm not looking for traction, because I was planning to buy drag radials for traction, but I don't even need them as it is. It has no problem at all chirping the tires into second gear and even catches third once in awhile...but just kind of chirps the tires off the line as well...odd to me. I had a 94 Z28 a4 that couldn't dream of traction when I put a 3.73 gear in it...I'm just finding this odd...the car drives great and doesn't lag off the line....guess I'm just more so curious, cause traction is great, but unexpected in this case....thanks Jason
Old Jun 15, 2003 | 07:04 PM
Hotwire's Avatar
you will notice a difference once the speedometer is reprogrammed.
Old Jun 15, 2003 | 09:27 PM
Fastrthnu's Avatar
So is the computer treating it differently than it should...once it is reprogrammed are you saying it will act different?
Old Jun 15, 2003 | 09:36 PM
Hotwire's Avatar
yes, computer uses speed as a adjustment for fuel/spark curves, and shifting points. your sig does not tell what year car you have, but on obdii cars, if you run around w/ the speedo out it will trip a ses light due to the abs sensors get out of whack that way. nothing serious though, just get it calibrated soon.
Old Jun 16, 2003 | 12:07 AM
Fastrthnu's Avatar
I plan to get the car calibrated soon...thanks....by the way, the year is in my sig...30th=1997 Thanks again Jason
Drtryder
Apr 22, 2015 04:17 PM
camy 1993
Feb 1, 2015 07:16 PM
Noer
Parts Wanted
Jan 19, 2015 10:19 AM
GRN96WS6
Sep 8, 2002 10:45 PM
funina91ss
Aug 6, 2002 11:20 PM
