396ci questions
Old Feb 1, 2005 | 10:07 PM
JJJ93z's Avatar
396ci questions
This summer I am going to begin building my 396, I have had a few questions so if anyone could answer a few that would be great. Thanks
Is there any good stroker books out there? LT1 specific
Am i going to have a problem b/c im still speed density?(1993)
use my existing block 70k miles or get another one.
2 bolt or 4 bolt main
what style pistons?
any other help would be great, this is my first time doing this and my research is still at the minimum, If anyone has any info on build ups or 396s in general. I basically want to run low 11's N/A so this motor would have 2 be reliable b/c its a daily driver in the summer, and will only be taken to the track no more than 3x a month during the summer. thanks again
Old Feb 1, 2005 | 11:02 PM
Dave19yz28's Avatar
Re: 396ci questions
pistons would depend on what you wanna do with the motor...and what comp. ratio you would want to run. if you are going to be boosted, forged is the way to go...
4 Bolt mains (crank walk would suck on a motor you are going to put all this $ in to)
*edit* that's not to say 4 bolt mains will eliminate it...but they will lessen the chances of it occuring hopefully...
shouldn't have a problem with speed density...that's sorta unrelated to cubes
the block should be fine, just have it thoroughly cleaned and inspected by your builder.
not an expert by any means...but hopefully that helps.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Victory Racing
Sep 12, 2002 05:41 PM
Victory Racing
Sep 12, 2002 10:40 AM
Victory Racing
Sep 1, 2002 05:34 PM
