396 Questions
Old Mar 10, 2005 | 11:36 PM
93 4mula's Avatar
396 Questions
Im thinking about building a 396 stroker, but I was wonder if my GM 847 was to small for it? Do any companys make any cams bigger then the 847 for our cars? Also my heads/intake have a pretty big port job to, will my heads flow that motor or should I get bigger valves put in and larger port work if possible!?! I want a bigger cam then the 847 if they make it.
Old Mar 11, 2005 | 12:21 AM
SStrokerAce's Avatar
Re: 396 Questions
Usually stock heads are not enough on a 396. You going with a $600-$800 Forged crank and pistons that have no overbore replacement.
A Custom cam would be the way to go, but why not do a 383 with a Scat or Eagle Cast crank. That will be more than you need and less $$$$
Bret
Old Mar 11, 2005 | 12:33 AM
viperkiller's Avatar
Re: 396 Questions
agreed. and yes i think the 847 will be a little tame for a 396. but you can contact some of the people such as joe overton and he can design one for you that will meet your needs. i think i remember a guy about a year ago hitting 450 rwhp on stock bottem end n/a.
Old Mar 11, 2005 | 12:47 AM
turbo_Z's Avatar
Re: 396 Questions
I bet Bret(SStokerAce) can design a cam to meet or exceed that number from what Ive seen recently. When I rebuild my motor he will be the first guy I talk to about cam/valvetrain options.
Old Mar 11, 2005 | 12:50 AM
Re: 396 Questions
You don't always need a huge cam in a 396 either.... There is lots of piston speed in there so a good set of heads will do the deal. I'm build a 396 now for a tame setup 2800 stall, 3.23 gears.... and that cam duration wise is really tame. The combination of all the parts should make that puppy do about 500+rwhp.
Small heads need more cam, bigger heads need less. A smaller cam is easier to drive so it's all what you want out of the thing.
Bret
Old Mar 11, 2005 | 09:27 AM
93 4mula's Avatar
Re: 396 Questions
Heres the link to the kit that Im going to buy. I guess Ill just have to get the flow numbers to my heads and get a cam based from there. The valves should be big enough though right ? And when you get the aftermarket oil pan is there any clearance issues with that when putting motor back into car?
http://www.cnc-motorsports.com/produ...095&CtgID=9038
Old Mar 11, 2005 | 03:09 PM
93 4mula's Avatar
Re: 396 Questions
Whats the difference in clearance issues as far as the 396 and 383? Also power difference?
transam_388
Mar 15, 2015 11:53 AM
pimpss96
Feb 12, 2015 01:28 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
