383 times and broken timing chain
Old May 17, 2005 | 11:23 PM
  #31
EDS Z28's Avatar
Re: 383 times and broken timing chain
You can find that chain at Scoggin Dickey, www.sdpc2000.com
It is for a '87 and up hydraulic roller cam.
The billet steel heat treated gears are made in Austrailia, the chain in Germany.
The timing cover needs to be clearanced a little bit and you have to run an electric water pump.
Old Jun 15, 2005 | 01:06 PM
  #32
Black_95Formula's Avatar
Originally Posted by stroked383ta
... i did a 5-6 second burnout before and still no luck. im getting et slicks.
This is off-topic but I read that doing a burnout on street tires does nothing for hooking. Burnouts are for slicks which actually get sticky when they get hot. I would also recommend to avoid the water they spray -- also for slicks not for street tires.
Old Jun 15, 2005 | 01:17 PM
  #33
Joes94TA's Avatar
I'd check into what caused the chain to break... before thinking it was the chain that failed.... Also factory Timing chains are pre-stretched ,meaning they will have slack in them....
Old Jun 15, 2005 | 06:51 PM
  #34
1racerdude's Avatar
Some of the slack ya may have is due to the smaller crank sprocket GM spect out for the LT-1.They do this to try to take some load off of the front cam brg with the gear drive pump.
Ya can get a Cloyes ED single roller with the GM spect crank sprocket or a standard size(oversized as compared to the GM one).According to Cloyes this chain is as strong or stronger than a double roller based on pin size
jb4xx
Feb 2, 2015 10:00 PM
Cam's maro
Jan 30, 2015 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
