383 stroker runs like a V-6
Old Apr 13, 2006 | 05:00 PM
hankisonc's Avatar
Unhappy 383 stroker runs like a V-6
Ok here it is everyone I need help. My friend recently had his 96 lt1 rebuilt into a 383 expecting to have a Hugh horse power increase. Instead the car is SLOW. I mean no get up and go at all. At idle the car sounds great but when you get into the throttle the car stumbles and makes loud back firing noises that sound like they are coming from the heads not the exhaust. We have checked fuel pressure, changed plugs, and changed wires, ran it with and with out the msd 6al, replaced the optispark system and treated the fuel. What do you think is the problem? Could it be a bent push rod or a lifter? I checked the valve springs and they look ok to me.
Old Apr 13, 2006 | 05:03 PM
BlackScreaminMachine's Avatar
Re: 383 stroker runs like a V-6
crossed wire
Old Apr 13, 2006 | 06:01 PM
96capricemgr's Avatar
Did he get it tuned.
How about ported heads?
Old Apr 13, 2006 | 06:33 PM
ajschult's Avatar
crossed wire or poorly adjusted roller rockers. maybe even off a tooth.
Old Apr 13, 2006 | 10:18 PM
hankisonc's Avatar
Well we checked the push rods tonight and they dont appear to be bent. we will check the plug wires soon.
Old Apr 13, 2006 | 10:19 PM
hankisonc's Avatar
__________________
1996 Formula Chamaleon m6
383 LT1 LE3 http://www.cardomain.com/memberpage/430619
Engine in the machine shop, soon to be done.
what do you mean by off a tooth???
Old Apr 13, 2006 | 10:22 PM
hankisonc's Avatar
it has reprogrammed by pcm for less after the rebuild. I guess the car ran good for a day or so then lost power.
Old Apr 13, 2006 | 10:41 PM
96ta(nick)'s Avatar
In that case it is most likely a burnt wire or 2.... Ask me how i know. lol
Old Apr 13, 2006 | 11:02 PM
AlmostfastLT1's Avatar
How do you know? haha jk
Mark
Old Apr 14, 2006 | 06:15 AM
hankisonc's Avatar
thanks for the advice everyone i will check it out to see if any of the wires are crossed or damaged.
D1SC383LT4
Jan 1, 2016 01:56 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Killer94z
Jan 13, 2015 12:06 PM
spearous
Jan 12, 2015 11:03 AM
