383 stroker problem
I have a 1994 Camaro z28 and when i got the car it ran perfect it ran 11.0 sec in 1/4 of a mile. and the second day i owned it something wasnt right cause i lost horsepower and it wont even do a burn out. i thought it was the vacume cause my brakes suck know but i dont know whats wrong with it. so can someone help me out.
ur question is going to be very hard to answer without looking at the car and listening to it....get a video of it running and maybe a IN CAR video of u doing a WOT run.....are u throwing ny codes??....was the motor running hot??....there are a lot of things u arent telling us so not many people are going to be able to help
With that attitude i offer you this advice. Get a little patiences and come back a little nicer. Try putting some car info if you really want our help. Mods and such.
Thanks for the positive review.
Let's get this straight... the 1st day you owned the car, it ran an 11.0. The 2nd day you owned it, it had no power. An 11.0-sec car is pretty quick, and must have a huge cam on an NA setup, or its running a blower or nitrous. How can anyone even start to help you with virtually no info about the engine.
Might want to rethink your attitude issues, and if you want help, compose a post with a comprehensive description of the car, the engine, and what you did between the 11.0-second pass and restarting it the next day when it had no power. Describe in detail how the engine starts and runs.... start OK? Idle OK? run a bit rough - at what RPM?
The more info you put in your post, and the less attitude you display, the more likely somone can help you.
Its up to you.
Its up to you.
