383 stroker---making a thumping noise-- *vid*--please help
Old Aug 26, 2008 | 07:37 PM
TA'95's Avatar
Angry 383 stroker---making a thumping noise-- *vid*--please help
Well guys i have a problem here.... My engine is making a "thumping" noise coming from the passenger side rear of the engine. I pulled the header gasket to see if that was it but it was fine. As soon as I start my car it drops to 700-900 rpms when it should be around at 1300-1400 rpms. It also stumbles some when i try to take off from a stop. And it also burns up alot more gas than normal-- i feel like i get 6 miles to the gallon. I believe these problems happened right around when the engine started making noise. It doesnt throw an SES light or any other codes. I also revved it a little in the pitch black night and i did see a couple small blue flames coming from the side of the engine. What are yall's guesses as to whats wrong with it? Exhaust leak? something internal? Your help would be greatly appreciated
engine vid.
http://www.youtube.com/watch?v=ZGB-vGmNUwU
Old Aug 26, 2008 | 08:15 PM
SS RRR's Avatar
Sounds like lack of valvetrain adjustment as well as a bad exhaust leak. I would suggest not driving it until the valvetrain can be readjusted.
Old Aug 27, 2008 | 11:42 AM
TA'95's Avatar
Is it accurate to say its an exhaust leak?
Old Aug 27, 2008 | 11:46 AM
boosted-lt1's Avatar
I found it a little hard to tell from the vid but I think SS RR has it. Try adjusting rockers with engine running and report back.
-Scott.
Old Aug 27, 2008 | 07:14 PM
SS RRR's Avatar
One way you can tell is by putting the car in a higher gear and giving it some gas. If the "tapping" becomes louder then it's an exhaust leak. From what I hear it sounds like a combination of both.
Old Aug 28, 2008 | 09:37 PM
TA'95's Avatar
Well guys, I just got back from having my car looked at by a car expert and he said its a definate exhaust leak. He said it sounds like its coming from the flange gasket that connects the header to the y-pipe.(dont know if its flange or donut gasket). He also said when i left my car blew out a flame from the tailpipe when i gave it some gas and spun out. Any thoughts?
Old Aug 29, 2008 | 03:17 AM
SS RRR's Avatar
Do you have headers? It indeed does sound like it's leaking from the yoke, but (maybe it's just the mic on the camera) it also sounds like you have a very noisy valvetrain.
You should check your spark plug boots and spark plugs to see if there is any carbon on them to make sure there are no leaks around the manifold/header flange.
Old Aug 29, 2008 | 02:52 PM
rx8ss's Avatar
You said you were getting poor milage, I would check the injectors for one that could be stuck open. Over fueling in one cyl could make that same noise.
Good luck
Also check valve adjustment, as above. I like doing it while running unless solid roller.
Old Sep 1, 2008 | 06:03 PM
TA'95's Avatar
well guys i found my problem, it was the flange that connects the passenger side header to the y-pipe. Tightened the bolts back up and 75% of the niose is gone. Although it does seem to still make a little thumping, I was told that could be due to the aftermarket heads or the cam in it. Any other thoughts? Thanks again.
Old Sep 1, 2008 | 07:31 PM
SS RRR's Avatar
Would like to see another video now that has been taken care of...
Old Sep 1, 2008 | 07:39 PM
TA'95's Avatar
alright, vid coming soon.
Old Sep 2, 2008 | 06:30 PM
TA'95's Avatar
http://www.youtube.com/watch?v=wVDs5ka_dWU.
new vid. thoughts?
Old Sep 2, 2008 | 09:46 PM
jpack24's Avatar
Man what rockers are you running? Or what video camera are you using. It sure don't sound right.
Old Sep 2, 2008 | 10:20 PM
TA'95's Avatar
Comp Promagnum 1.6 rockers- non-self-aligning. It does have a little bit of a "gargling" noise from under the valve covers on both sides.
Old Sep 2, 2008 | 10:25 PM
LaredoZ28's Avatar
Sounds like u have rocker problems. if you want some good rockers u can go with these.
CCA-1305-16 COMP Cams Pro Magnum Roller Rocker Arms
Rocker Arms, Stud Mount, Full Roller, Steel, 1.6 Ratio, Fits 7/ 16 in. Stud, Chevy, Small Block, Set of 16
Tomorrow $285.95
or
CCA-1416-16 COMP Cams Magnum Steel Roller Tip Rocker Arms
Rocker Arms, Stud Mount, Roller Tip, Steel, 1.6 Ratio, Fits 3/ 8 in. Stud, AMC/ Chevy, V8, Small Block,Set of ...
Tomorrow $157.95
I have personally used the second ones and they worked great. no noise at all.
