383 stroker kit
Old Dec 13, 2003 | 01:37 PM
Everett's Avatar
383 stroker kit
Hello
I have 97 z and i want to build the engine and need some help. I was thinking about putting a 383 stroker kit, porting and polishing the stock heads, putting the lt4 gm performance hot cam kit, and headers. What do you guys think about what i am planing??? also where is the best place for prices and quality???
Shane
Old Dec 13, 2003 | 02:41 PM
BadAssed93Z's Avatar
go bigger than a hot cam
gm 847 or cc306 are really popular
so are the XE custom grinds
as for the kits other will chime in with those im interested to because i havent bought my kit yet
Old Dec 13, 2003 | 02:58 PM
akafred's Avatar
hotcam
dont listen to the hotcam is to small bs!!!!
hotcam is great and leaves you with tons of low end torque!
look in my sig of what my hotcam makes on the roller!
Old Dec 13, 2003 | 03:04 PM
DrewHMS97SS's Avatar
the hot cam is a good cam, but if hes going 383 there are much better cams he could try. I for one would 2nd the 306 over the hotcam.
i would ditch your heads too. look into the lt4 heads and do work to them.
if you are looking at buying a kit, or a whole motor, check out nu-tek, they do some good stuff.
Old Dec 13, 2003 | 04:27 PM
akafred's Avatar
engine
how much power do you need?
how much do you want to spend?
emissions? (my hotcam 383 did better than stock)
Old Dec 13, 2003 | 04:28 PM
Hetfield's Avatar
zz409.
Old Dec 13, 2003 | 04:33 PM
Re: hotcam
i never said the hotcam is a small cam, i said go bigger
obviously it can make power but wouldnt the cams i suggested make more
im going to a 383 and ill have a cam custom ground.
he asked what we think, and thats what i think
Old Dec 14, 2003 | 12:27 PM
BlueCamaroZ28's Avatar
Originally posted by Hetfield
zz409.
That's what TPiS recommended to swap my ZZ9 cam to for a 383 stroker build.
Old Dec 14, 2003 | 12:54 PM
Everett's Avatar
Hello
Thanks guys I am looking for around 450 to the wheels. i don't need the car to do 150mph or nothing but want it to be quick and maybe run around 130 or so. I am on a budget but also want the car to be very reliable as a daily driver a know a am asking alot but that is was i want and have all winter to do it. thanks for all the help guys What do you think i will have invested into the moter???
Shane
Old Dec 14, 2003 | 12:58 PM
flyinZ's Avatar
Ya, the CC 306 has wiked top end pull..you'll like it..
Old Dec 14, 2003 | 02:34 PM
akafred's Avatar
450hp
if you want 450 hp go bigger than the hotcam! and you will need some pretty good heads! like afr 195's or bigger
Old Dec 14, 2003 | 02:41 PM
the 306 is a pretty good cam for what it sounds like he wants to do.
Old Dec 14, 2003 | 03:13 PM
How is LT4 conversion on top of a 383 stroker. How much HP does it equal?.
Summit Racing claims a proven 425+HP (Flywheel) with the LT4 conversion kit including LT4 Hot Cam.!!
Old Dec 14, 2003 | 03:44 PM
flyinZ's Avatar
Re: 450hp
I hope you mean 450RWHP, not the fly'....
Old Dec 15, 2003 | 02:34 AM
S.J.S.'s Avatar
Hey bud....look at my mods below. What's funny is that I had the exact same idea in mind when I built mine. I am totally happy with it and the cam. I actually think its a bit much some times. But remember this dude. It's like a snowball. You do the motor and everything else has to go with it. Injectors....computer....TB.....tranny build up...converter.... The list is endless. I went about 3k over budget. But ask me if I regret it.
