383/stock radiator??
Old Oct 5, 2004 | 02:54 PM
BadAssed93Z's Avatar
my 383 will be going back in soon and i was wondering how many guys here have strokers with the stock radiator? and if there are any problems?
also what are my options for a larger/aftermarket radiator and an electric water pump? anybody with that combo? ive heard tou have to trim the fan shroud anyway which makes me think a larger radiator wont be an option. any truth to that?
any comments, suggestions, advice is appreciated.
thanks
Old Oct 5, 2004 | 02:56 PM
WS Sick's Avatar
Re: 383/stock radiator??
Yep stock radiator has been working fine for almost 2 years. (I do want a nice Be Cool one though)
CSI and Meziere both make good elec water pumps, each have their installation quirks.
Old Oct 5, 2004 | 03:10 PM
sssalah's Avatar
Stock radiator here as well, controls the temps well even with ac with ambient temp of +110 degrees.
Old Oct 5, 2004 | 03:16 PM
zhevy-1's Avatar
Stock radiator, stock waterpump, and 160* Thermostat, and it's been running cool for 2-3 years now.
Old Oct 5, 2004 | 03:20 PM
Type_O_Negative_1320's Avatar
385 LT1, stock radiator, 160* thermostat, CSI electric water pump...my temp gauge never goes over the first hash mark on the gauge (185*).
Old Oct 5, 2004 | 03:28 PM
well im convinced then, thanks alot for all the responses.
Old Oct 5, 2004 | 03:41 PM
WS Sick's Avatar
No Problem, I will also note that I'm using the stock waterpump with a 160 degree thermostat as well.
I plan on adding the CSI to mine since I have seen it perform flawlessly on my freinds car that we installed it on. My car rarely peaks above 180 degrees. We normally have very hot summers here, but this year we only had a handfull of 100 plus degree days, each day the temp was rock steady.
Old Oct 5, 2004 | 08:55 PM
TQdrivenws6's Avatar
383/heads/cam/full boltons/csi/160 thermo Have yet to see above the first mark.
Old Oct 6, 2004 | 12:01 AM
thanks again for all the replies,
and TQdrivenws6 im also hoping for 420+rwhp out of my new combo so wish me luck.
Old Oct 6, 2004 | 10:41 AM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
398 solid Roller
No problems with the cooling system ever.
Neal
Old Oct 6, 2004 | 12:32 PM
398 solid roller... wow.
i drastically under estimated the stock cooling system.
thanks
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Pwilson59
Sep 3, 2015 08:47 PM
