383 rotating assemblies
Old May 2, 2003 | 12:58 PM
R_Andersen's Avatar
I'm wondering if anyone has used the 383 rotating assemblies from either cmotorsports or nu-tek? I plan on using the setup with the Scat 9000 crank and was looking for some info on them. They say the assemblies can be balanced there, and I was wondering if these are fully internaly balanced or internal/external balanced like stock LT1's?
I plan to run the Street Twin clutch and I'm wondering if the flywheel that comes with it will be compatible with the rotating assemby from one of the two vendors? I am assuming the Street Twin flywheel is balanced for the stock LT1 crank that is externally balanced in the rear.
Thanks for any help,
Rob A.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
Str8hp
Parts Wanted
Aug 25, 2015 06:03 PM
