383 Machine Work?
Old Jul 15, 2005 | 03:36 PM
ChrisUlrich's Avatar
383 Machine Work?
For an Eagle rotating assembly... 3.75" stroke, 6" Rods, and -5cc SRP Pistons...
How much fabricating has to be done to either the block or crank to make it turn smoothly and work correctly? Yea I know bore/hone/align bore/etc...
I mean how much shaving and mallory must be used to make the crank turn smoothly? To keep from hitting the oil pan rails
Old Jul 15, 2005 | 03:49 PM
sssalah's Avatar
Re: 383 Machine Work?
It's the oil pan rails that must be notched slightly in some places to clear the rod bolts from hitting this area, the crank throws wont come close. The rotating assembly needs to be partialy assembled and rotated to determine where to notch. It's better to maintain at least 0.05" clearance between the rod bolts and block.
Old Jul 15, 2005 | 04:32 PM
What did you (or anyone) pay for the machine work and assembly of the bottom end? I am hearing crap like 5k when I was hearing originally like... 2-3k?
Old Jul 15, 2005 | 04:39 PM
Victory Racing's Avatar
Machine work varies from shop to shop, I would say 800-1500 is a broad gauge. For that you should get the block full machined with deck plates, stroker clearanced as well shot peened and hot tanked.
As for assembly, that varies as well. Your best bet is to contact an engine builder you want to use and see what his prices are.
Old Jul 15, 2005 | 04:49 PM
Do you guys take block and assemble them for people who need to mail them in? I wouldn't mind sending my block far for it to be done correctly at a price that isn't 10k
Old Jul 16, 2005 | 06:21 PM
Chris, I look forward to your stuff arriving at the shop.
D1SC383LT4
Jan 1, 2016 01:56 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
nballisru
Dec 14, 2014 05:01 PM
