383 Le2 Seems Down On Power
Old May 30, 2006 | 10:55 PM
playa7970's Avatar
*ok lets see where do i begin with this thing even though i may get bashed for this but oh well,i mean dont get me wrong from 3500 to 6800rpm the car pulls like hell but whenever it gets down to 1000 to 3000 it just falls flat on its face the car just doesnt seem that different from stock exept from
70mph and up.
*Problem number two idle issue.... car at idle sucks.. i know it has nothing to do with the cam or motor. its either some kinda sensor or somethin. at a stand still when im even slightly about to accelerate the stumbles there no throttle response and you can hear backfire comming from the intake..i cant even take off full throttle from a dead stop its like i have to ease into it
*and last problem i dont know if this is normal or not but when i pull my dip stick to check the oil from the tube itself this white smoke comes out very faint though same thing when i remove the cap the engine is new is this normal??? i appolagize for the long story but i appricate the people out there taking the time to read it im really just angry outta all the cash i dumped into this only to be disappointed....and i know my rear end is stock but would that really make that much difference??? Thanks
Old May 30, 2006 | 11:15 PM
SStrokerAce's Avatar
Re: 383 Le2 Seems Down On Power
The low RPM stumble can be knock or ignition. Check for those two first.
The backfire deal can be related to valve adjustment.
Bret
Old May 30, 2006 | 11:20 PM
playa7970's Avatar
thanks for the reply when we scanned it for codes it came back with MAP and ICM could that effect it in any way also shouldnt the valve adjustment been already done by Golen?
Old May 31, 2006 | 07:40 AM
MEAN LT1's Avatar
Yes, the ICM and the map can affect performance. As far as valve adjustment goes, even if Golen did set the valves I would go over them again with the motor running unless they did this already.
Old May 31, 2006 | 08:07 AM
Javier97Z28's Avatar
Moderator
I'm tellin' ya.. 1000-3000 rpm is not where it's at anymore with your setup...
3600 stall and at least some 3.73's and you won't even be in that part of the powerband anymore...
Old May 31, 2006 | 08:08 AM
playa7970's Avatar
what should i use to do this and is there such a thing as over tightening them? also can the clack be from the lifters this is my first time with RR...damn it im such a noob at this
Old May 31, 2006 | 08:10 AM
playa7970's Avatar
ill take your word on it javier im buying me a strange rear then the stall can wait till i have enough to save for my tranny oh yea whats that white fainted smoke im seeing comming outta the oil cap and dip stick tube
Old May 31, 2006 | 08:16 AM
Moderator
Yes, you will hear additional noise from the roller rockers... if you've never heard them before they are a bit louder than stock.. but the noise shouldn't be excessive. I'd let someone go through your valve lash process again. Not sure what lifters you have, if they are OEM style go with 1/8-1/4 turn after zero lash.
Not sure on the white smoke coming out of the dipstick tube and oil cap.. is the engine hot when you are doing this?
And yes, the MAP and ICM are definitely issues you need to look into. The MAP could be overtightened... doubt it's that though.. it's probably reading something it doesn't like....
You have to remember you've made a big jump from I believe a bolt on car? to what you have now.. it's two totally different animals with two totally different powerbands.
Old May 31, 2006 | 08:24 AM
playa7970's Avatar
yea the engines hot when i check the oil.... hey javier wanna meet half way so you can set my valve lash lol
Old May 31, 2006 | 08:29 AM
Moderator
lol i'm a little burnt out from working on mine
Old May 31, 2006 | 08:31 AM
playa7970's Avatar
damn i gtg to work now but keep em post rollin and any idea what that white smoke is it cant be the piston rings can it i mean the motors new
Old May 31, 2006 | 08:46 AM
jsetzer's Avatar
I see you have forged pistons, what kind of gaps are being run on them?
I have a tiny bit of blowby and I get a little bit of white smoke if I open something up while its warm.
Old May 31, 2006 | 09:15 AM
playa7970's Avatar
i have them set at .50 so you get the same thing huh guess it might be normal?
Old May 31, 2006 | 10:13 AM
The ring gaps at .050"!!!!
Old May 31, 2006 | 10:15 AM
playa7970's Avatar
lol oh im sorry i thought he meant spark plug gap i have no clue on what the piston rings are set at
