383 Issues
Old Oct 13, 2007 | 05:32 PM
  #16
chief455's Avatar
Originally Posted by awdfun
I had some vibration. I did not really pay attention to it. I am glad I caught this early too about 475miles. There was a little shimmy on the harmonic balancer that had me worried so that why i went looking. The caps are rear main and the 4th cap inline. There was no damage to the crank luckily. The machine shop says whenever I install a new clutch to have the whole assy rebalanced again.
you mean for now - just use the flywheel you're having balanced and install new main bearings?
next clutch install, pull it apart and rebalance?
or EVERY time you install a clutch?
Old Oct 13, 2007 | 07:40 PM
  #17
awdfun's Avatar
Everytime you install a new clutch you need to have the flywheel and pressure plate rebalanced as a complete assy, Or in most cases just have the balance checked. The machine shop said most of the times the pressure plates are balanced from the manufacturer. I am probably going to run the motor for 1000 miles or so then check the bearings again. Its a expensive investment and I do not want to mess it up.
Old Oct 14, 2007 | 06:12 AM
  #18
chief455's Avatar
In 30 years of this hobby I've never heard that before. It makes perfect sense - always something to learn, thanks and good luck!
Drtryder
Apr 22, 2015 04:17 PM
cheapchevy
Apr 8, 2015 08:48 PM
Chevyguy358
Jan 28, 2015 08:04 PM
deadmanrunning
Jan 3, 2015 01:12 PM
