383 help
Old Jul 16, 2011 | 01:00 AM
twistedbowtie's Avatar
Question 383 help
ive just built a lt1 355. i have flat top mahle pistons new stock rods/crank. i found a guy with a new 383 crank he is willing to let go very cheap (link below is the same crank). my motor is complete oil pan to intake but would realy like to make it a 383 if i can just pull the oil pan and remove the crank and use all my other parts (rods ,pistons, ect.)
http://www.summitracing.com/parts/ESP-10352375057E/
my main concern is ive never messed with a 383 so can i just swap cranks or what is the biggest part to doing this? thanks
Old Jul 16, 2011 | 05:01 AM
bw_hunter's Avatar
Re: 383 help
No, you can't. The piston you have are designed with a 3.48" stroke so they have the pin placement pretty far down from the top. If you put a 3.75" stroke crank in there, the pistons would be above the deck height at TDC. (that means they'd stick out of the bores by about a quarter inch). At a minimum you'll need new pistons/rings to go with a 383. Then you need some more machine work on the block to clear the rotating assembly. You'll be starting over, basically.
Also, if you're building a performance engine, don't go with a cast crank....
Old Jul 16, 2011 | 09:18 AM
Kevin Blown 95 TA's Avatar
Re: 383 help
He's right about the pistons and block, and that crank isn't a very good one, either, so I agree with everything said in the above post.. You will probably be happy with your 355 anyway.
Old Jul 16, 2011 | 10:48 AM
Re: 383 help
alright guys thanks alott ive never realy done anything with a stroker motor so i had no clue
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
smoknta
Aug 27, 2015 05:07 PM
alphaauto
Jul 26, 2015 04:40 PM
