383 Help
Old Jan 30, 2005 | 07:11 PM
96camaroz28lt4's Avatar
383 Help
What is need to make my LT1 into a 383? I have a LT1 that is modded and I can use my cc306 still right. Also about how much more HP will a 383 make?
Old Jan 30, 2005 | 07:19 PM
mustangmuncher's Avatar
Re: 383 Help
You will need a 3.75" crank, and .30 over bore on the block, with 4.030" pistons, and whatever size rods. Some say if your going NA to go with the longest rod possible, and with FI to use a smaller rod (5.7") This is just a rough understanding that I have. You will need ported and polished heads and matched intake to keep up with the extra air the engine asks with the extra cubes. Of course you can use your CC306. don't cheap out on the machine work, that is the most important part of an engine.
Old Jan 30, 2005 | 08:16 PM
94zgreenmachine's Avatar
Re: 383 Help
a big bank account. I have almost 5k in mine and I still haven't bought the converter and pcm program yet. There are numerous "little" parts creeping up on me so I suppose you'll need a big bank account and patience
Old Jan 30, 2005 | 08:25 PM
blue's Avatar
Re: 383 Help
I would like to know these questions and they go along with the thread: Do you need a new oil pump with a 383? Or if you have fairly high miles should you get a new one? How much? Are there any other parts you must have with a 383 (I don't mean heads, cam, injectors, tb, clutch, 12-bolt, or anything like that; I mean just what you need to get it going without having to yank the whole engine out of car again to replace it. Anything you would just be stupid not to replace or upgrade while the block is out.)
Old Jan 30, 2005 | 08:36 PM
Re: 383 Help
A new oil pump would be a good idea and a quality one from More Performance with the pick up already welded is about $80, I think. Bearings and rings. Don't forget to clearance the oil pan. I had to do the back corner but that was a few love taps with a ball peen hammer. Nothing serious. I didn't think I had to but when I turned it over by hand the oil pan was shiny in that spot. It didn't take much and hardly seemed bad at all but I played it safe.
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
smoknta
Aug 27, 2015 05:07 PM
alphaauto
Jul 26, 2015 04:40 PM
