383 Eagle Crank
Old May 8, 2006 | 12:35 AM
97silvermaro's Avatar
383 Eagle Crank
lets say oughta curiousity what would have to be done to put in the 383 eagle crank on the stock rods and pistons? would you have to clearance for the stock rod length? would an aftermarket dampner have to be used? i believe it would make the motor a 377ci ??? and ive heard that the ls1's use the longer stroke smaller bore method... (ive only heard. i havent researched this nor am i stating it as a fact) how would this smaller bore bigger stroke work on the lt1's?
Old May 8, 2006 | 02:01 AM
sssalah's Avatar
Re: 383 Eagle Crank
Couldn't be done with the stock pistons as they would stick out of the block 0.135". Could be done with lower piston that has a compression hight of 1.45" instead of the stock 1.585". Yes the displacement will be 377.
LeftoverChinese
Jan 14, 2024 03:03 PM
Drtryder
Apr 22, 2015 04:17 PM
transam_388
Mar 15, 2015 11:53 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
