383 Dynoed today
Old May 12, 2004 | 08:49 PM
supermo26's Avatar
383 Dynoed today
I dynoed the car today at a shop in FLorida. about as sea level as your gona get. Car made 403.3 HP on the Second pull. 403.2 on the 3rd pull.
Im wondering if I could gain any HP buy changing the exhaust around a little. I have Hooker LT's with Mufflex Y reduced to 3 inch. I have a bent I pipe to connect to the Hooker Cat back. Maybe I need to change the muffler to a offset in center out, or center in center in muffler to get a better flow. Or maybe the same muffler in a 4 inch pipe instead.
Injectors are SVO # 42. I may change them to 36's or so and increase the fuel 3-5% with programming. Air Fuel ratio showed car running on the lean side.
Im happy to be in the 400 HP CLUB! I want 430 or so though.
Old May 12, 2004 | 08:52 PM
Spinner's Avatar
What kind of cam/heads?
Old May 12, 2004 | 09:19 PM
zlightning's Avatar
I'd try a cutout before getting a whole new exhaust.
Old May 12, 2004 | 09:35 PM
supermo26's Avatar
Comp 236 242 112LSA
AFR 210 Comp Ported
Old May 12, 2004 | 09:43 PM
97 RedSS's Avatar
Yea with those heads Id expect alot more than that..Im dynoing that w/o tuning and 30# injectors..
Cody
Old May 12, 2004 | 09:57 PM
bunker's Avatar
That cam doesn't seem to make much power in any engine, I have no idea why, it has great mid range but just dones't give you those peak numbers. get a custom cam or a GM847
Old May 13, 2004 | 01:48 AM
1982z28with18s's Avatar
Get a custom cam.
Old May 13, 2004 | 07:14 PM
supermo26's Avatar
Headders are comming out for repair work and re coating.
The I pipe that connect to the Y-pipe suck so I want to replace it with something better. I also want a stright threw muffler. Im just not sure if I should run 4 inch or 3inch pipe over the axel.
Old May 18, 2004 | 09:46 PM
supermo26's Avatar
would a 4 inch I pipe and muffler be over kill?
Old May 18, 2004 | 10:27 PM
z28_4life's Avatar
just do true duals...problem solved...
Old May 18, 2004 | 10:49 PM
96z's Avatar
96z
Nice numbers.
Old May 18, 2004 | 10:56 PM
hsyr's Avatar
Yea I must say every post I see with dyno #'s that involve that cam have terrible #'s. I bet going to a GM847 or custom cam would bring you up to 430+rwhp atleast with heads like those in a 383. JMO
Old May 18, 2004 | 11:29 PM
NBS4's Avatar
Some how i expected more from a Stroker
Old May 19, 2004 | 10:03 AM
WS Sick's Avatar
What does the torque look like?
Old May 19, 2004 | 11:15 AM
Gripenfelter's Avatar
Do true duals!
