383 Dyno Numbers See Inside
Old Aug 13, 2003 | 09:11 AM
  #16
Gripenfelter's Avatar
378rwhp@6200rpm 383lb ft torque
Thats with a 700R4 and a 3200 stall converter (3% more drivetrain loss)
The dyno guys said with a T56 it would have been over 400rwhp.
I wouldn't worry too much about your dyno numbers if your MAP was unplugged. You should be easily over 350rwhp with proper tuning.
Old Aug 13, 2003 | 03:33 PM
  #17
SnkEatr's Avatar
Thanks Fred I was looking for some input on the MAP sensor. I seemed to think that the car was running in open loop, and using some default timing maps to run on. Anyway I will try to get her on the dyno again, before to much longer. My original goal is to run 11's NA I think that is doable without new heads. there seems to be guys running stock heads (that have been worked) putting down 400+ rwhp. lets see what tuning will do.
Mike
Old Aug 13, 2003 | 07:20 PM
  #18
Rpm280's Avatar
Mike
Please post the numbers when you get the MAP issues taken care of.
Old Aug 13, 2003 | 07:22 PM
  #19
Rpm280's Avatar
Originally posted by 1slowlt1
i have to agree with everyone else.
i have a 97 z with a 355 forged interals 210/224 cam and stock heads that are ported and polished and i put down 403RWHP and 378RWTQ with stock exhaust manifolds. that was with a very safe tune.
i think there is alot of room for improvement.
Who did the heads?
Old Aug 13, 2003 | 07:33 PM
  #20
JordonMusser's Avatar
West South Central Moderator / Special Guest
1slowLT1-
did the track numbers back it up? 400rwhp should be good for 118 depending on conditions.
Old Aug 14, 2003 | 04:00 PM
  #21
SnkEatr's Avatar
Map Issues are taken care of the connector fell out of the sensor, it is now held in place with a tie strap. Will dyno next time our club has a dyno day. $30 for three pulls is an awesome price.
Old Aug 15, 2003 | 01:54 AM
  #22
Fastbird93's Avatar
I wish!!! I'm paying $200 per 3 pulls with wide band, and that's the cheapest around!!!
Old Aug 15, 2003 | 10:04 AM
  #23
RealQuick's Avatar
50 bcks around here all the time for 3-6 pulls with A/F. Dont need a special dyno day.
Old Aug 15, 2003 | 12:12 PM
  #24
Fastbird93's Avatar
I don't know why it's so dang expensive around here. Cheapest one I know of is SLP at $175 for three pulls.
It sucks, especially when you're trying to get a speed density car dialed in with mail in tunes.
Old Aug 15, 2003 | 12:16 PM
  #25
$75 u.s. 3 pulls on wideband.
Old Aug 15, 2003 | 12:21 PM
  #26
Fastbird93's Avatar
Rub it in some more, a**!
Old Aug 15, 2003 | 07:47 PM
  #27
1slowlt1's Avatar
my engine was built by More Performance out of Charlotte, NC. here are the specs on the engine:
- 355 CID
- stock LT1 heads that are ported and polished with 1.6 RR, double springs, titanium pushrods and titanium retainers
- custom gound cam 210/224 with a 510/550 lift and a 112 LSA
- 52mm TB
- steel crank, lunati race rods, 4.03/3.48/5.7/-5 flat top pistons, all fed mog coated bearings
- comp. ratio is 10.8:1
i also have all the usual bolts on's with a loudmouth and cats with stock manifolds
i have been really impressed with the motor.
rob
Old Aug 16, 2003 | 06:53 AM
  #28
texasTA's Avatar
I still call Bs to 1slowlt1.
Let me get this straight your call name on here is 1slowlt1, but yet you have possibly the highest dyno i have ever seen on here with a very small cam and stock manifolds. Sorry, but without a dyno sheet and verification of mods, BS. unless your car was built on a day when EVERY GM plant employee recieved an extra week vacation and a 10000 bonus.
As to the 383 with cc306, get that bad boy tuned and eventually some GOOD heads and the sky is the limit.
Old Aug 16, 2003 | 07:13 AM
  #29
SnkEatr's Avatar
I have to agree with TexasTA on this one, there is no freakin way in hell a 355 with that small of a cam, and stock manifolds is going to put out that kind of HP. UNLESS it is strapped to a mustang dyno!!!
Old Aug 16, 2003 | 07:18 AM
  #30
texasTA's Avatar
Exactly. I mean Stock GD manifolds, not even shorties. BS BS BS BS BS
