383 build and waterpump drive
Old May 28, 2006 | 03:39 PM
arcticz28the383's Avatar
Well I was puttin my 383 together and I ran into a problem. I was planning on using my stock waterpump for the build, but the bearing was bad inside it. Instead of buying a new stock water pump, im just going to install a electric one now. The issue is, I have my timing cover on with the water pump drive in. If this isnt connected to the waterpump and is just sitting there spinning, will that cause any sort of a problem? Or should I be ok?
Old May 28, 2006 | 03:57 PM
Javier97Z28's Avatar
Moderator
Re: 383 build and waterpump drive
Eh.. if the bearing is getting ready to seize up i'm not sure I'd run it with the timing set...
Old May 28, 2006 | 04:01 PM
I guess I might have worded that wrong.. The water pump drive underneath the timing cover is fine. The bearing INSIDE the water pump was bad. My question is if it would be ok to just leave that water pump drive in so I don't have to take the front cover and timing chain back off.
Old May 28, 2006 | 04:08 PM
1racerdude's Avatar
Take it out.
Old May 28, 2006 | 04:26 PM
Josh'95Z28conv's Avatar
Yea, you need to take it off and have the hole welded up.
Old May 28, 2006 | 04:56 PM
Moderator
I'd take it out personally. The hole can be covered up with a quarter and some quicksteel.
cheapchevy
Apr 8, 2015 08:48 PM
transam_388
Mar 15, 2015 11:53 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
