380+rwtq is this possible for stock bottom end Lt1
was wondering if anybody was getting large torque numbers out of there stock bottem end LT1?
what cam?exhaust set up? what rpms where these numbers at?
With NA m6 cars & no auto flashes? Sure, 'round 5k... ~230deg int duration.. shorties... 3" catback...
Not too difficult, though peak anything isnt what I worry about really. Not too hard to do if everything is in order
Yes its possible, there are a fair number of people in the 370s, but I believe 380 can be done expecially if you have that wonderfull Texas gas to work with. My car was making AWESOME off idle torque but I had random ping and could not dial it out with 91 MTBE Crapifornian stuff, so I had some power loss to deal with, although mostly in the 1400 and under powerband. With some tolulene experimentation though it was awesome, I wonder what peak torque would have been with that stuff.
Guest
Posts: n/a
don't worry as much about where the peak torque falls. how flat is is will get you to the end of the track quicker.
why are you looking for a torque peak below 4k rpm? in that case you should stay with milder camshaft grinds with less than 220º at .050.
i made a little better than 460 hp at the rear wheels with a 355. torque peak was at about 5200 with better than 400 ft lbs from 3600 on up. cam was a solid roller, head flow was less than 260 something cfm at peak. the rpm peak was 6700 rpm.
JB
JB
oldschool
Feb 9, 2016 09:21 PM
