380 hp what will it run
Old Feb 17, 2008 | 03:30 PM
Steve Buckley's Avatar
Full weight dyno 389 hp 3:73's m-6, what ya think
Old Feb 17, 2008 | 03:39 PM
mrmint69's Avatar
Street tires? There are to many variables like temp, elevation to be exact. Whats all been done? A good suspension will help along with many other things.
Old Feb 17, 2008 | 03:47 PM
96m6lt1's Avatar
on what tire? gear?
with that to the rear wheel you should see low 12s w/traction etc.
Old Feb 17, 2008 | 04:02 PM
Klypto's Avatar
no wya to know besides letting her rip on the track, but im guessing... 12.4 - 12.9
Old Feb 17, 2008 | 04:04 PM
Yes no suspension yet except frame ties, but micky drag radials, spec clutch, I think 12.20s
Old Feb 17, 2008 | 05:20 PM
mrmint69's Avatar
You have the location not listed. This would play a part.
Old Feb 17, 2008 | 05:53 PM
I am in Kentucky and the cars run well here if elevation is what you mean. The car pulls hard if it will get off the line without breaking the rear, it does have a built up 7.5
Old Feb 17, 2008 | 05:55 PM
2000GTP's Avatar
With those numbers, you should have a low 12 second car. That could always change though and there is only one way to find out.
Old Feb 17, 2008 | 06:05 PM
We are hoping for 12.20s and then gonna do a dry shot and shoot for low 11's
Old Feb 17, 2008 | 06:10 PM
mdacton's Avatar
12.99
Old Feb 19, 2008 | 08:35 PM
my94blackz's Avatar
12.0
I went 12.1 with 380 RWHP Full weight M6 and 3.73's, lowered with bfg's. Course I drive the hell out of my vehicles.
Old Feb 19, 2008 | 08:59 PM
FASTFATBOY's Avatar
If you can DRIVE 12.20 ish at 113 ish
David
Old Feb 19, 2008 | 11:51 PM
SS RRR's Avatar
Originally Posted by my94blackz
12.0
Indeed. If the car truly has that power number and is geard for the power band and the driver can drive and the track is prepped well 12.0's should be in the bag with 1.7 60' times.
However... because 400rwhp cars only are turning mid to low 12's at 110 to 113.... you just never know.
The above is supposed to be a joke yet is a sad one since it seems to be the norm these days.
Old Feb 20, 2008 | 12:03 AM
Steve in Seattle's Avatar
Post
Depends how bad a driver you are. :/
Every yokl thinks THEY can drive... but driving isn't racing... especially with a stick.
Old Feb 20, 2008 | 07:55 AM
TRICK95's Avatar
To even guess it would help to have more info and there are tons of variables that could put you close to 12 flat to low 13's, depending on any number of factors. My guess is 12.5x's. But then again, I don't normally get the greatest launches off drag radials and an M6, but many others will be able to pull it off just fine.
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
