357 build ?s
Old Mar 20, 2008 | 01:27 PM
9formula4's Avatar
357 build ?s
Ok so i am building a 357 tie over motor. Now my plans are to reuse the stock crank and rods but I am using a set of forged Speed Pro pistons. I am also going to mill the heads .010"- .015" and the block is already zero decked. Now my questions are as follows (and i just want the questions answered)
1) The pistons are floating pin pistons, are the stock rods going to work?
2) Will I still be able to run the impala headgaskets with no pisto/valve interference? (pistons are 4 valve relief)
Now remember this is ONLY A TIE OVER motor til my stroker motor is completed so no comments about buying new this or anything like that. The only way I am going to buy something new is if the rods wont work with the pistons since I already have them.
Thanks in advance guys.
Old Mar 20, 2008 | 01:38 PM
speed_demon24's Avatar
I can't answer #1, but #2 depends on what cam you are running.
Old Mar 20, 2008 | 01:48 PM
9formula4's Avatar
I am gonna run a cc306 cam.
Novo
Jun 14, 2016 02:58 AM
CARiD
Sep 30, 2015 05:44 AM
pepon214tx
Sep 20, 2015 04:48 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
reww86
Aug 29, 2015 06:04 PM
