355 Rotating Assemblys???
Old Feb 28, 2005 | 07:51 PM
Rich_z28's Avatar
I'm planning on tearing the motor out this next fall/winter and want to start getting things around. I'm not looking for a setup thats bullett proof, but I'm not going with a setup thats cheap either. I definately want forged. I'll do the assembly myself, so I'm not looking for a short block. Who's packages do you guys recommend? Thanks for any input.
Old Feb 28, 2005 | 08:36 PM
n2oblkz
Guest
Posts: n/a
Re: 355 Rotating Assemblys???
You can go to Eagle's site, they sell complete rotating kits for your needs that will allow you to pick a compression ratio to suit your needs. Also, what may be best would be to piece a kit together yourself. Scat makes a good forged crank at a reasonable price and sometimes you can get really good deals on new Eagle cranks from distributors. Eagle and Scat rods are really good and SRP and Diamond make very good pistons. If you are not going forced induction (you can even use the stock with FI), you can get by with a stock crank if you are not going to turn it too high.
Check the site below periodically, they have some really good deals in clearance on cranks, especially Eagle.
http://www.cnc-motorsports.com/category.asp?CtgID=7154
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
cmsmith
Aug 27, 2015 06:37 PM
Str8hp
Parts Wanted
Aug 25, 2015 06:03 PM
Dams76
Aug 20, 2015 08:28 AM
