355 Rotating Assemblys???
I'm planning on tearing the motor out this next fall/winter and want to start getting things around. I'm not looking for a setup thats bullett proof, but I'm not going with a setup thats cheap either. I definately want forged. I'll do the assembly myself, so I'm not looking for a short block. Who's packages do you guys recommend? Thanks for any input.
Guest
Posts: n/a
Re: 355 Rotating Assemblys???
You can go to Eagle's site, they sell complete rotating kits for your needs that will allow you to pick a compression ratio to suit your needs. Also, what may be best would be to piece a kit together yourself. Scat makes a good forged crank at a reasonable price and sometimes you can get really good deals on new Eagle cranks from distributors. Eagle and Scat rods are really good and SRP and Diamond make very good pistons. If you are not going forced induction (you can even use the stock with FI), you can get by with a stock crank if you are not going to turn it too high.
Check the site below periodically, they have some really good deals in clearance on cranks, especially Eagle.
http://www.cnc-motorsports.com/category.asp?CtgID=7154
cmsmith
Aug 27, 2015 06:37 PM
