355 LT1 Shortblock Reccomendations
Old Feb 12, 2006 | 08:27 PM
Steve0's Avatar
After thinking it over, I've decided to forego installing a cam in my car and just build a 355 to swap in. My goals are to build a stout 355 making ~400rwhp. By the time I install the motor my Z will no longer be my daily driver, but I still want the car to remain streetable. I'm looking for advice and opinions on this project.
I plan on purchasing a stock shortblock, and rebulding it using the stock crank. I dont plan on spraying the motor so I'm not too worried about having the strongest components. Basically, I plan on bumping up the compression, putting on a nice set of heads and shifting ~6500rpm. I want a nice motor, but I'm in college and on a budget. I hope to have the bottom end built this summer.
Has anyone on this board built a 355 LT1? Any recoomendations on a rebuild kit? I was thinking about running forged pistons and rods, but is that really necessary if I dont plan on spraying the car? Could I reuse the rods and just get better pistons? I have done searches, emailed members etc., but everyone is doing something different. Some run a stock crank, while others convert to 4 bolt splayed bottom ends with eagle cranks. I dont want to spend excess money and overbuild my motor when the cars only going to be driven on the street. I've had the car 2 years and have been down the drag strip maybe 6 times.
I am trying to sort out all this now so I can see what this is going to cost me. Any advice/suggestions is appreciated.
Old Feb 12, 2006 | 08:46 PM
Jameslt1TA's Avatar
Re: 355 LT1 Shortblock Reccomendations
How many miles are on your stock shortblock?
My setup consists of:
stock crank
lt4 4-bolt block with billet main caps
forged scat i-beams
forged and coated mahle pistons
It was built for spray. Your right on not needing forged internals unless your gona stray aways from a n/a motor. If your under 100k miles or just over, i would just do a heads/cam kit. Probably an le2 to keep it streetable and make around 400 rwhp. Check a recent thread on here a guy made 417 rwhp with a stock short block.
But if you did want to do a rebuild i would reuse the stock rods have them reworked and fitted with arp rod bolts though. Forged pistons would work good but a good set of hyperuetectic(spelling?) pistons would be fine for a n/a 355. I know that summit racing has some pretty good deals on rebuild kits that come with pistons and bearings and such.
Also remeber that you will need to find a good machine shop to perfom the machining and put the bottom end together if you dont trust yourself to assmling it.
Good luck
James
Old Feb 14, 2006 | 10:13 AM
SStrokerAce's Avatar
What James said sounds good to me.
I would get the crank polished (not reground).
You don't need the 4 bolt mains, but they dont hurt. Just go with a set of ARP studs in the mains and you will be good to go.
Bret
Old Feb 14, 2006 | 11:13 AM
94 guy's Avatar
i can get you a deal on scat rods and some pistons. i just built a shortblock for a really good price. pm me.
Nostang 96z
Sep 15, 2002 10:15 PM
Nostang 96z
Sep 14, 2002 08:22 PM
Nostang 96z
Sep 10, 2002 08:54 PM
Nostang 96z
Aug 31, 2002 12:01 PM
