View Poll Results: 383 or 355
355
16
31.37%
383
35
68.63%
Voters: 51. You may not vote on this poll
355 or 383???
Old Jun 13, 2006 | 08:02 PM
  #16
joe-96z1le's Avatar
Re: 355 or 383???
"Adding displacement is the quickest, easiest, and often least expensive way to increase power throughout the entire rpm band, especially in the lower rpm range where torque is king." -- John Lingenfelter on modifying small block Chevys.
Old Jun 14, 2006 | 09:45 AM
  #17
blkchevyz's Avatar
Re: 355 or 383???
i'd do a 383 for these reasons
you can run a bigger cam and still be driveable/emissions, more torque, and more room to grow(better heads later)
now i'd do a 355 if your trying to stay in a budget... using stock rods, crank and after market pistons. you will be able to do that for way cheaper then a 383
Old Jun 14, 2006 | 01:09 PM
  #18
CALL911's Avatar
Re: 355 or 383???
Originally Posted by 93turbo5oh
i had a buddy with an MTI heads cam combo on his stock shortblock m6 95 z28 back in 96-97. it made 390rwhp, ran low 12s@116. the ported stock heads heads flowed 255 and the cam was about 240* @ .050". when the stock shortblock was worn out mti built a 396 shortblock for it and used the same cam and heads. it made 435rwhp, and ran 11.30s@123. it makes a difference.
How can you use the same heads when the heads off a stock short block are the incorrect size for a 396? Maybe I am missing something here, but the heads would at least have to be modified to work wouldn't they? And if so, that alone can make up for the extra HP. I should have worded my statement slightly different regaurdless. A 383 over a 355 will add MOSTLY more torque, and yes probably a few more HP, but mostly torque. Bigger upgrade to a 396 would be even a larger difference.
Old Jun 14, 2006 | 01:19 PM
  #19
Javier97Z28's Avatar
Moderator
Re: 355 or 383???
No, there's no "fitment" issues. They may not flow well enough to feed the engine to its best potential but they will work. The deck doesn't change on a 396, will get decked most likely, but that only affects height and piston to valve clearance (which should always be checked)
  #20
blkchevyz's Avatar
Re: 355 or 383???
he's probably had his lt1 stroked to 396
Old Jun 14, 2006 | 01:21 PM
  #21
CALL911's Avatar
Re: 355 or 383???
Gotcha. I have no problem admitting to when I just don't know. Thats why I like these forums. Thanks for the info.
  #22
93turbo5oh's Avatar
Re: 355 or 383???
it was a 396 cubic inch LT1. as in 4.030" bore and 3.875" stroke crank. a 383 is a 4.030 bore and a 3.75" stroke crank.
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
smoknta
Aug 27, 2015 05:07 PM
alphaauto
Jul 26, 2015 04:40 PM
