View Poll Results: 383 or 355
355
16
31.37%
383
35
68.63%
Voters: 51. You may not vote on this poll
355 or 383???
355 or 383???
Im about to order a new short block and im trying to decide between a 355 or 383. I will be using a CC305 cam, 1.6 RR, SLP ST (dam NJ
) and the heads will be ported. Is it really worth the few 100 extra for the 383?? any idea how much more power the 383 will make??
Re: 355 or 383???
Tough question. I went with the 355 because it's still modest and you can make tons of power. I would hate to disappoint with a 383 that doesn't run as well as it should. I like impressing people with my lil' ol' 355. It's hard to explain.
Re: 355 or 383???
I say you might as well go 383, I just built mine and everything seems to be fine but that cam is going to hurt you and make sure you have LT's. Also if you go 383 get some bigger injectors, I'm going to 50# but 36 should do fine. It's going to cost you more for the 383 to run right, the 355 will run off of basic 350 stuff, I had a 360 and ran great on cc306 but moved to cc468 for my 383 .584/.579 w/ stock ratio rockers so I'm alittle over .600 w/ the 1.6's.
Re: 355 or 383???
Originally Posted by hsyr
If your not going to do it right, stick with the 355. If your willing to spend the $ on the right supporting mods (Higher flowing heads/intake) then IMO 383 all the way
Re: 355 or 383???
Originally Posted by speed_demon24
The 383 will not be any faster unless you spend more $$ on the heads/intake, ported stock heads are too small for a 383...
Re: 355 or 383???
for a given cam the bigger motor will be more driveable and pull more vacuum. even with a ****ty set of heads you can usually make an extra hp for every cubic inch. bigger motors are easier on the valvetrain as well.
Re: 355 or 383???
Originally Posted by CALL911
Save the $, go with the 355. A 383 shouldn't make any extra HP with the same parts as in a 355, just more torque.
