355 or 383
Old Sep 10, 2003 | 03:30 PM
  #16
rage366's Avatar
ceteris peribus, a 383 makes more power than a 355 just simply because of the displacement.
Old Sep 10, 2003 | 04:23 PM
  #17
OldSStroker's Avatar
Unfortunately rarely is "everything else equal", even in the 383/355 world.
While you should see more low and mid range torque from a 383 with all other things the same as a 355, when it comes to max horsepower, there might not be the 7-8% advantage you would expect. The 383 needs more air, so unless you give it some, you might be spending a lot of money for little power increase.
(Where's the good Latin spellchecker when you need it?)
Old Sep 10, 2003 | 05:08 PM
  #18
Got-LT1's Avatar
Originally posted by Z28SORR
Got-LT1
You seem confused. You were once a hardcore stroker guy but you're not an expert. But you know, because Frank told you, that you can make more power with a 355. In theory (not theroy), Frank's a genesis but theory is not real world is it?
"It is far wiser to remain silent and have others think you a fool, then to speak and remove all doubt"
When I said I was a hardcore Stroker guy all I meant was that the only engine I wanted was a stroker. All I was doing was giving a point of view that is not often seen. After have a discussion with Frank, I did a search and found most of what he said was true. Is there something wrong with learning from a wise person? I don't consdier myself an expert with strokers because I NEVER built one.
and don't make fun of my spelling, i know I can't spell!
BTW: did you mean Genius?
Old Sep 10, 2003 | 05:32 PM
  #19
rage366's Avatar
ceteris pAribus...
given equally proportionate mods, a 383 will put out more tq and hp, will it not?
Old Sep 10, 2003 | 06:07 PM
  #20
S.J.S.'s Avatar
I'm gonna skip all this stuff and speak from experience. I threw some bearings on my stock LT a month ago. I considered both and looked into it heavily. Everyone here is comparing apples and oranges. Jona kinda hit it on the head. They all are right in their own way. But anyway I'll try and answer both questions you have.
It would be cheaper to build the 355 because you wouldn't need a new crank, they could just cut the old one if needed. But my crank was screwed so I had to toss it (why I went with the 383 ). But there was a lot of hidden costs. To get the most of the 383, I had to get a bigger TB, decent cam, 1.6 rockers, beef up the tranny, larger injectors and most of all the heads. Not to mention some other lil stuff here and there. Granted there was things I added that I didn't need but go figure. Also I'm sure some of these mods I would have put in anyway if I went with the 355.
The bottom line is this......like anything else it all comes down to what you want. But the main consideration is the old "CASH" thing.
But yeah all things being equal of course the 383 will be stronger not more so because of the C.I. but the torque it puts out.
The key there is "ALL THINGS BEING EQUAL"
good luck
Old Sep 10, 2003 | 06:41 PM
  #21
BlueCamaroZ28's Avatar
For the same build of top part, the 383 will be around 80FWHP more than the 355 but with more increase of torque. If we are comparing apples with apples and oranges with oranges. I hope it is clear now.
Old Sep 10, 2003 | 06:42 PM
  #22
ceteris pAribus...
Sure but then it wouldn't be ceteris paribus, would it?
It would just be expensive.
barrister or economist? (Just teasing. That's the only places I hear that term.)
Latin isn't the native Lone Star language yet, is it?
Old Sep 10, 2003 | 10:31 PM
  #23
a_z28_vance's Avatar
Originally posted by BlueCamaroZ28
My 355, see my mods list in my sign, makes 400FWHP.
Considering 15% drive losses, that's 340HP at the wheels.
I made that without the 355, using a small cam, and my heads flow less then stock LT4 heads.
So you think that you will make roughly 68rwhp more(15%loss) with a 383 than a 355 with the EXACT same mods?? Think again..... You will NOT see a dramatic increase of hp just b/c it is stroked. You WILL see a gain in torque though.
Old Sep 10, 2003 | 10:52 PM
  #24
rage366's Avatar
nope, mexican is the native language.
lol, neither barrister nor economist. finance.
perhaps i should have explained ceteris paribus in the context of my argument. i guess my logic that it would still be ceteris paribus if things were proportionate doesnt make sense...(it made sense to me ).
i figured that price wasnt an issue here...he just wanted to know which would be faster if properly "fixed up."
Old Sep 10, 2003 | 11:12 PM
  #25
95Bird's Avatar
They both have their advantages. I went with a high reving 355 ...seems to be doing pretty good. Several have stated it right though..the hp is in the top end. Give the exact same setup you won't see I big difference in a 383/355. A large cam in a 355 is gonna be tamed down in a 383. The 383 will need more air...which means the heads need to be better...which brings in the factor that you will need more cam to flow the air. Its really apples to oranges. Saying that.. a well thought out engine...with different parts for each according to their total setup...the 383 will make more power in my honest opinion.
P.S. I've beat so many stroker lt1s and big bore ls1s it crazy...like I said total setup.
Old Sep 10, 2003 | 11:19 PM
  #26
LilJayV10's Avatar
I asked this exact same question a few weeks ago and didn't get one damn reply. A fellow board member, Flyboy82A, is wanting me to build an engine for his 93Z this winter. He mentioned wanting to do a 383 but I mentioned a 355 with Total Engine Airflow's 11 second head/cam package. Anyone know anything about this package? I know they are a very reputable shop.
Jason
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
smoknta
Aug 27, 2015 05:07 PM
alphaauto
Jul 26, 2015 04:40 PM
