315 Nitto Drag Radials. What best psi to run them on the street?
Old Jun 27, 2003 | 06:04 PM
xxsaint69x's Avatar
I was wondering what PSI you guys recommend on the 315 DRs. I know if u over inflate them, the center will wear out pretty quickly. I heard anywhere from 20-35
Marcin
Old Jun 27, 2003 | 06:11 PM
Mindgame's Avatar
I run ~32 psi.
-Mindgame
Old Jun 27, 2003 | 06:17 PM
xxsaint69x's Avatar
any problems with middle wearing out faster then the outside?
Old Jun 27, 2003 | 06:33 PM
Mindgame's Avatar
Well, I've got about 700 miles on em (didn't use them at the track) but the wear looks even so far.
I think Nitto recommends using the factory spec pressure rating but I don't see a prob with ~30 psi.
-Mindgame
Old Jun 27, 2003 | 10:31 PM
1982z28with18s's Avatar
I was running 32 in them but the middle was wearing a log faster than the out edges. I dropped them down to about 28 earlier tonight. I'll see how much it helps.
Old Jun 27, 2003 | 11:25 PM
Rasta's Avatar
PSI on 315 dr
I run 18 psi at the track and 22 on the street and they still ware more in the center. I would run no more that 24 on the street.
Old Jun 28, 2003 | 02:58 AM
What rim width you running? I've got 11". When I first got the 315's I tested different PSI in them by burning out and seeing what gave me the most even black mark and 26psi gave the best results.
Old Jun 28, 2003 | 03:00 AM
Brettinator's Avatar
Re: PSI on 315 dr
I agree, in fact I ran better with 22 at the track and about 24 or so on the street. I tried a lower psi at the track and it slowed me a little. Going to WELD draglites soon so I'll be running something all together different anyways.
Old Jun 28, 2003 | 09:14 AM
xxsaint69x's Avatar
i guess ill be traying 22ish...i have 17x11 in the back.
Marcin
Old Jun 28, 2003 | 10:01 PM
I can actually tell it rides a little softer with 28 instead of 32. I might run the next pair at 26. BTW, how many miles is everyone getting out of them? My last set lasted about 14,000, but this set seems to be wearing much quicker.
Old Jun 28, 2003 | 11:36 PM
notstock4long's Avatar
So somewhere around 24-26 psi seems to work good? What is the factory spec on this anyway? I thought it was like 32, but I can't remember
Old Jun 28, 2003 | 11:51 PM
xxsaint69x's Avatar
i droped mine to 22 psi COLD..so i am sure its goin to be around 25 hot....we will c how that works out.
Marcin
Old Jun 29, 2003 | 06:28 PM
97FormulaWS-6's Avatar
I'm running 275's so mine are a little different, but @ 25psi cold... mine were almost in the center and almost new on the outside quite quickly.... I dropped them to about 15psi cold and they started to wear more evenly, but still not how i;d like to see it.
I think it'd due to being such a soft tire.. it actually acts like a slick, and grows at higher speeds, similar to what you see a top-fuel car do as the tire goes from wide and short to tall and narrow... I'm thinking the Nitto's do the same thing, although no where near as extreme.
Old Jul 16, 2003 | 01:31 AM
Bringing up an old post, but I've dropped my down to 24 cold. I talked with some of my buddies who run 18 on the street all the time with no problems. I might try dropping them down some more after I look at theirs and talk to them again.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jason Short
Jan 19, 2015 06:33 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Brad 97z
Aug 10, 2002 09:58 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
