306 valve springs 1.6 rockers, never found an answer.
Old Jul 17, 2005 | 09:13 AM
djm_e22's Avatar
I have looked several times and haven't found an answer or only answers like "these springs should work". Can someone please tell me what springs will work with my 1.6 crane cam roller rockers with a 306 cam? I think the lift is .544 and .576 with the 1.6rr, which is higher than the 1.5rr that normally goes on the 306 cam. The compcams site shows a certain spring to use but it is for the 1.5rr. Any help would be appreciated, thanks.
Old Jul 17, 2005 | 09:38 AM
ZMAN Z28's Avatar
Re: 306 valve springs 1.6 rockers, never found an answer.
Cc-26918-16
Old Jul 17, 2005 | 10:46 AM
truedualws6's Avatar
Ditto the 26918s. Here is more info >>
Parts needed to install Comp 26918 beehive springs on a stock
aluminum head LT1 (for iron heads just omit the spring seat).
7 degree hardware with 4705-16 spring seats (1.73" installed
height):
787-16 retainers
648-16 locks
10 degree hardware with 4705-16 spring seats:
795-16 steel retainers, or
794-16 titanium retainers
611-16 locks (standard), 1.70" installed height, or
614-16 locks (+.050), 1.75" installed height
For either installation you will need spring seats:
4705-16 spring seats, .062" thick
Old Jul 17, 2005 | 03:03 PM
30696bird's Avatar
height):
787-16 retainers
648-16 locks
I looked for the 4705-16 seats on comp's site and on byunspeed......they say it don't exsist.
Old Jul 17, 2005 | 03:11 PM
Daniel6718's Avatar
crane 10308 in mine...direct swap, no machining or anything
Old Jul 17, 2005 | 03:18 PM
Z95m6's Avatar
918's should work. Contact Bret Bauer, he can help you with 918 bee hive setups. Thats where i got mine.
Old Jul 17, 2005 | 03:32 PM
flyinZ's Avatar
Yep, me too...The 987's would work also.
Old Jul 17, 2005 | 04:02 PM
30696bird's Avatar
So........can you use stock seats or do you HAVE to get the 4705-16 seats?
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
Red_94Formula
Jan 22, 2015 12:17 AM
Jazsun
Dec 29, 2014 12:14 PM
