306 and stall?
Old Mar 6, 2005 | 12:26 PM
95formy's Avatar
306 and stall?
I have a PTC 2500 stall converter and 3.73 gears. will the converter be sufficient enough for a comp 306 cam?
thanks Billy.
Old Mar 6, 2005 | 03:00 PM
96m6lt1's Avatar
Re: 306 and stall?
comp says that you need a 2500 or more to use this cam,if you only use a 2500 you will be giving up some potential of this cam.
the cc306 comes to life at 2500 so you should have a minimum of 3000 stall so if i were you i would just get a 3500-3800 like most of us have with this cam.....as a rule you should have a stall that stalls 1000 rpm after the cam begins to start this helps to get the car into the power band,i noticed you were using nitrous so get a stall that has anti-ballooning plates in it as well as all the goodies to make it last!the cost here is well worth the price!
Nayr
Mar 3, 2023 08:34 PM
truecontr3
Oct 11, 2015 09:30 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
damnyankee36
Sep 9, 2015 07:06 PM
