306 cam, ported head was tuned w/ 48mm now going with 52mm do I....
Old Sep 15, 2007 | 04:00 PM
djm_e22's Avatar
I had my 306 cam with ported heads tuned by pcmforless with a 48mm throttle body with 30lb fuel injectors. Now I'm going with a 52mm throttle body. Is this really that big of a mod that the computer can't adjust accordingly needing me to send it off again or should I just use my air fuel gauge(Innovate Motorsports) to make sure it doesn't lean out?
Old Sep 15, 2007 | 04:42 PM
93v8clone's Avatar
id sent it out but if ya got a a/f gauge check it out and go from there it may mess wit the tranny shifting somehow though as far as throttle input i beleive but call brian and ask hes a straight up guy he'll tell ya the truth
Old Sep 15, 2007 | 05:18 PM
Stl94LT1's Avatar
I'm thinking it won't be a problem.
Old Sep 15, 2007 | 05:41 PM
Old Motorhead's Avatar
If you have a pcmforless tune, you've obviously dealt with them before. Don't hesitate to contact them. They're a good easily available resource. Use them. When people like that are a phone call or email away, why chance a problem?
Old Sep 16, 2007 | 02:29 PM
95Blackhawk's Avatar
I assume you have no data reader such as DataMaster? Sounds like the mod will be simple enough not to cause fueling issues.
Old Sep 16, 2007 | 02:38 PM
danhr's Avatar
automatic or manual transmission?
auto: absolutely yes
manual: I wouldn't bother, unless you are within i think it's 30 or 90 days of purchasing your tune, in which you get a "redo" for free, then I would
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
skittlez87
Dec 29, 2014 03:23 PM
jmzlt1
Mar 13, 2003 07:26 AM
