Is a 305 worth building for racing??
Old Mar 30, 2004 | 08:30 PM
white97z/28's Avatar
Just bought a small block chevy a while back, found out it was a 305 a few weeks ago when i ran the numbers on it. The guy i bought it from swore it was a 350 so i took his word for it and bought it. So far i know it is a 88-92 model 305, don't know if it was roller cam or non roller though, has 55cc heads with good sized valves. As of now I have a 600cfm edelbrock elec. choke carb, performer RPM manifold with 1'' spacer, longtubes, and a mild cam inside. Don't know the specs on the cam but it is not outrageously huge. Judging by the since it already had a performance camshaft in it when i bought i would bet it was a non roller engine. Anyway, what kind of power could i expect out of this engine with maybe a more radical cam inside and a 4 speed tranny. I was wanting to hit 350 hp. I already chunked it in my 69' chevelle before i knew it was a 305 so i really dont wanna have to take it right back out yet. Havent had a chance to drive the car and see what kind of horses it is making but will pretty soon after everything is complete. It does sound like a healthy engine and has good compression. I was just wondering if throwing a bigger cam and a set of heads on it was worth it or just sell it and get a earlier model 350. What do you think?
Old Mar 30, 2004 | 08:33 PM
Allwaysbroke Z's Avatar
I had a 1992 camaro with a 305 in it... Save yourself some time and money and just get a 350.. that 305 is garbage IMO.
Old Mar 30, 2004 | 08:34 PM
badazzcamaro97's Avatar
I would say go for a 350, I know people who haven't been successful with a 305 in their dirt track cars
Old Mar 31, 2004 | 09:02 AM
jcolez28's Avatar
Hey I went through that with a tpi TA with the 305. I wasted a fortune trying to get it to go fast, only to go home depressed night after night. Get rid of it as fast as you can!!
Old Mar 31, 2004 | 11:30 AM
WS Sick's Avatar
Unless youre just wanting to prove a point, I would dump the 305 and get the extra cubes.
Old Mar 31, 2004 | 02:05 PM
TA76's Avatar
Just to play devil's advocate...
343hp 305
http://www.hioutput.com/tech/343hp/343hp.html
Car Craft or Hot Rod, don't remember which, did a build up of a 305 using a Comp Cams mild XE cam and Vortec heads, got 325hp out of the little sucker.
Old Mar 31, 2004 | 02:51 PM
95_LT1_6SPD's Avatar
i think hot rod got 400hp out of a 305 a long while ago, but its not worth it. Just go to a 350, you will be ALOT happier, 305s blow.
Old Mar 31, 2004 | 03:00 PM
DarkRider's Avatar
I used to have a 305 ta. I t was cool becaude it was my first car but once I got my lt1 I noticed how much 305's SUCK.
I would not recomend using it!!!!!!
ps - with my stock 305, ricers used to beat me
Old Mar 31, 2004 | 08:04 PM
pearlpurple's Avatar
If you do decide to build up the 305 here is an interesting read.
As far as I understand the smaller bore size in the 305 limits it's breathing at higher RPM's, I think they can be made with some low end grunt but the engine runs out of steam once you get up in RPM.
http://www.goingfaster.com/spo/praisetbi.html
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
Moshbmx1
Jan 20, 2015 03:27 PM
