300rwhp
Old Jun 25, 2004 | 04:55 PM
ARTIC_Z's Avatar
300rwhp
is there any other bolt on's that i can do to get my car up to 300rwhp. i have 275rwhp with mods listed in sig. thanks
Old Jun 25, 2004 | 05:04 PM
jkipp84's Avatar
Tough to do with bolt-on's and an A4. Without popping valve covers - real CAI, cheapest tb foil you can find, CSI pump, and a tune from madz28. These will get you closer to that 300rwhp goal.
BUBBA's Avatar
1.6RRs and a tune.JMHO
Old Jun 25, 2004 | 05:07 PM
BUBBA's Avatar
Yup. Add the CAI along with the RRS and tune and I believe you are in good shape.
Old Jun 25, 2004 | 05:14 PM
HardcoreRM125's Avatar
A decent CAI and 1.6RR's ... Dont get cheap on the rockers though, anything that goes INSIDE the engine, its worth the extra $$$ to buy the quality product instead of the "cheapest" set ...
As far as a CAI, it doesnt matter much which brand, just get one with a KN filter. Lingenfelter's have the same KN and the FIPK and are like 40$ cheaper. Seems to be made of decent quality. I like mine.
Old Jun 25, 2004 | 05:26 PM
Rocks94z28's Avatar
dont get g2 cold air intake
Old Jun 25, 2004 | 05:30 PM
ARTIC_Z's Avatar
what does the tune do for a manly stock motor? and how much is it?
Old Jun 25, 2004 | 05:32 PM
ARTIC_Z's Avatar
what rr's do u guys recomend? and will i need to change anything in the valve train if i do this?
Old Jun 25, 2004 | 05:51 PM
jkipp84's Avatar
Comp Cams Pro Magnum roller rockers are very good. They're not the cheapest, but for what you get for your $, I think they're a great deal. Springs will be needed with these. Some have gotten by with leaving the tired stock ones in, but that's not exactly the most intelligent way of going about it. They're not designed for the geometry change the new rockers will introduce anyway.
If you're serious about the rockers, contact a shop to put a package together for you to ensure you get all the right stuff - that works together. www.cmotorsports.com is a great place to start. They're good on prices and customer svc.
Old Jun 25, 2004 | 06:32 PM
n2oblkz
Guest
Posts: n/a
I made 300 RWHP and 314 RWTQ with my 1996 6spd Z-28. That was without tune and on a computer that died on me as we pulled it off the dyno! I have done some more work since then so I hope to get some better numbers. If you are up for the change, I would suggest long tubes with a 3 inch y pipe. Definitely the Comp 1.6 Pro Magnums. I will post my mods later, I'm not on my home computer and there are too many mods to start listing. BTW-443 RWHP and 514 RWTQ with 150 shot!
Old Jun 25, 2004 | 06:41 PM
mebanditws6's Avatar
A good CAI such as a Moroso and a tune might get you there. If not, you could get away with a pulley and probably get there without doing rockers. That built tranny is costing you some hp too so keep that in mind.
Jason
Old Jun 25, 2004 | 07:39 PM
ARTIC_Z's Avatar
well i cant do long tubes b/c i live in california i know the stall is costing me hp and tq is what i was told at the dyno. but ill be happy with 300rwhp with bolt ons or not major mods.
Old Jun 25, 2004 | 07:46 PM
ARTIC_Z's Avatar
are these the ones?http://store.summitracing.com/default.asp?target=esearch.asp&N=110&Ntk=KeywordSe arch&Ntt=pro+magnum+roller+rockers
Old Jun 25, 2004 | 08:14 PM
Cman's Avatar
look at my sig
I dyno 305hp/320 torque @ the wheels with my mods, keep in mind though I have a M6.
Tony
One thing I didn't list is TBB, that's done on my car also.
Old Jun 26, 2004 | 03:11 AM
n2oblkz
Guest
Posts: n/a
Here are my results and my mods to get 300RWHP.
Dynojet results
Motor: 300.3RWHP 314.RWTQ
75 Shot: 343.2RWHP 379.5RWTQ
100 Shot 404.8RWHP 469.0RWTQ
150 Shot 443.7RWHP 514.2RWTQ
Black 1996 Z-28, 6spd with Pro 5.0 and Lou's Short Stick and MBA ****, K&N cold air, 52MM polished TB, Granatelli Mass Air Flow sensor with polished ends. Crane valve springs, Comp hardened push rods w/guide plates, Comp Pro Magnum roller rockers. Hooker ceramic coated long tubes with mufflex Y pipe, SLP Dual/Dual Cat back. MSD 6A, MSD coil, MSD plug wires, NGK TR6 plugs. March underdrive pulleys. Auto meter electric Fuel pressure and nitrous pressure gauges in pod and Scanmaster. Granatelli 255lph in tank pump. Aeromotive adjustable fuel pressure regulator. 6AN braided fuel lines rerouted from factory location. DMS drop springs, BMR control arms, adj. panhard rod. Spohn weld-on lower control arm relocating brackets. Enkei Win wheels with 275/40/17's in front and 315/35/17's in back. Polished aluminum radiator cover, polished aluminum valve covers, polished aluminum Vortech elbow, chrome alternator, ceramic coated intake, ceramic coated water pump housing with Mezeire Electric water pump, ceramic coated accessories bracket and TNT F-1 nitrous kit with purge, NX bottle opener and NX bottle heater.
