30 over bore ques
Old May 8, 2005 | 05:02 PM
93redlt1's Avatar
30 over bore ques
I am building a 355 so i am getting it bored 30 over by a local shop in ny. anyway the engine builder not the honer said that the shop needs the pistons first but the honer said he could do it without. My ques is who do i believe. any help is appreciated.
Old May 8, 2005 | 05:22 PM
MaxLean's Avatar
Re: 30 over bore ques
If they are doing the job correctly, they will need the pistons that you will be using. The reason for this is that although the entire set may be .030" over, there will be some slight variation (maybe as much as .001"). With the pistons in hand, they can mic them and hone it's respective bore for that particular piston, resulting in more acurate and consistant piston clearances for the entire set.
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
Z Power
Sep 19, 2015 11:19 PM
heus
Sep 8, 2015 12:01 PM
