3 channel vs. 4 channel ABS
Which f-bodies have 3-channel vs. 4-channel ABS?
I was under the impression that all ASC equipped cars have 4-channel and all LS1 f-bodies have 4-channel. Everything else has 3-channel. Is that correct?
I need to know because I'm looking at trading my rear with someone else and he isn't sure what he has.
Thanks,
RichJ
Thanks,
RichJ
Here's a VERY simple solution to your problem
If he "isn't sure what he has", just tell him to look for the reluctor wheels on both rear axles. If the axles have reluctors, the rear end is from a four(4) channel ABS system. No reluctors, and it's a three(3) channel system
Hope this helps?
Hope this helps?
Henson071
Sep 21, 2015 04:31 PM
