3 bolts and a rusted ECT away from saying screw it.
Old Dec 21, 2004 | 02:44 PM
fesgali's Avatar
I can't get the 3 bolts on the balancer and the ECT off the waterpump.
Trying to change the opti and the f'en crank pully is in the way. Everytime i turn the bolts to loosen them the whole crank turns instead of the bolt.
And earlier when i was trying to switch waterpumps the plastic plug in of the ECT on the waterpump broke. And now i want to put in a electric one and need to replace it and the crap won't come out.
Anyone got any ideas on what to do.
Old Dec 21, 2004 | 03:15 PM
Bad64chevelle's Avatar
Re: 3 bolts and a rusted ECT away from saying screw it.
Thats why theres a bolt in the center of your balancer. Toss another wrench on there and turn them in opposite directions....breaker bar is usually needed! Thats how mine was, one two three it was off!
Old Dec 21, 2004 | 03:21 PM
fesgali's Avatar
I'm also replacing the timing chain...so would it be a good idea to just remove that center bolt to take out the hub and balancer all together?
Old Dec 21, 2004 | 03:34 PM
Javier97Z28's Avatar
Moderator
Use an impact gun, that'll take care of it
Old Dec 21, 2004 | 06:21 PM
Evil Eric's Avatar
i agree. you can wedge a thick screwdriver in there somehow and break thre bolts loose. use alot of liquid wrench and a breaker bar.
Old Dec 21, 2004 | 07:57 PM
Rpm280's Avatar
I would NOT turn the center bolt one way while loosening the 3 bolts.
Do like someone above said ,and put something in there that will wedge against the pulley and block so it won't turn like a big screw driver ,breaker bar, crow bar, etc. Or have someone hold the pulley so it won't turn, or if you are strong enough , you could possibly hold it with one hand and loosen with the other hand. Also i think if the car is in gear, the engine won't rotate much.
Old Dec 21, 2004 | 08:02 PM
Spinner's Avatar
I prefer to pull off the flexplate shield and wedge a prybar against the flywheel/flexplate. Stops the motor from turning.
Old Dec 21, 2004 | 10:14 PM
If it's a manual (the original poster does not give this info), just put it in gear and the parking brake on.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
nballisru
Dec 14, 2014 05:01 PM
squarehead
Nov 21, 2014 08:02 PM
