3.73 series
Old Aug 10, 2003 | 12:30 AM
QCKZ28's Avatar
Question 3.73 series
does having the 2 carrier 3.73's make the rearend weaker by not being a 3 carrier?
also for all the ppl who has these gears does your's whine? mine do really bad after the car sets for a few weeks....then gradually gets better....the are STRANGE gears btw.
if they whine does that mean they are more likely to break???
thanks
Jesse
Old Aug 10, 2003 | 12:39 AM
Cmr0z28's Avatar
the 2 series carrier has a thicker ring gear than a 3 series. they are stronger.....most aftermarket gears whine....richmonds being the most.
Old Aug 10, 2003 | 01:33 AM
QCKZ28's Avatar
thanks, the guy who put them in says there installed perfect, he double checked'em. that kinda eases my mind. also
how long do you think my rear would last with my combo??
3.73+2800 stall+transgo+heads/cam+drag radials
Old Aug 10, 2003 | 01:37 AM
Cmr0z28's Avatar
if you hook, it can blow up, u never know.
some guys run 10s on their stock rear with mickey thompson ET streets cutting 1.4 second 60' times, and other guys break their rears stock....personally i would run street tires and go easy when launching.....i wouldnt wana hook with that combo, thats for sure!
Old Aug 10, 2003 | 01:39 AM
QCKZ28's Avatar
thanks bud, you talked me out getting DR and going for TB/injectors
Old Aug 10, 2003 | 01:41 AM
Cmr0z28's Avatar
heh just go easy when launching and you'll be fine with the street tires (as long as the track is prepped good)
good luck!
93 RedBird
Nov 15, 2015 08:24 AM
SEOJustin
Sep 24, 2015 04:39 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
