3.4L to LT1 Swap Questions
Old Jan 24, 2007 | 11:18 AM
bkpliskin's Avatar
If I have the engine, transmission and wiring harness from a 94 Z28 LT1, what else will I need to get ahold of to drop it into a 94 Camaro with a V6? I've got a limited slip rear end that I'm putting in it also. Will I need a new gauge set up? What else will I need to make this work?
Old Jan 24, 2007 | 11:26 AM
2000GTP's Avatar
I believe you will need a new cluster due to the differences in rpm, speed, oil pressure, and water temp. You will definitely need an LT1 k-member and motor mounts.
Old Jan 24, 2007 | 11:37 AM
bkpliskin's Avatar
I'm new to this game. I've only had my Camaro since May 2006 and I've never done anything like this before. I'm having most of this work done by a local mechanic I like to go to who is pretty inexpensive. What is a K member? and how much will that run me?
Old Jan 24, 2007 | 11:40 AM
2000GTP's Avatar
Its the engine cradle, basically the platform in which the engine sits, if you check out the classifieds, you may be able to find a used one for under a hundred bucks. Otherwise, they do make aftermarket ones, which are tubular and lighter, but these run close to five hundred dollars.
rocketman051894
Jan 30, 2015 03:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
Jul 4, 2005 05:00 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
Zomie
Jul 22, 2002 07:43 AM
