2nd Opti Install And Its Leaking Again??? (pics Inside)
Old Nov 13, 2006 | 11:21 PM
playa7970's Avatar
this car is a nightmare i swear lol anyways after my second opti install its leaking around it, not coolant but oil. i know its not from the waterpump drive shaft because im running a electric waterpump and the timing cover is blocked off and the water pump has the brass seal. the motors new about 1800 miles and i cant believe this **** is leaking, any input on where i can start? thanks again guys and yes the opti was installed with both o ring seals and positioned correctly. oh yea and its a 95 and up style vented opti conversion
Old Nov 13, 2006 | 11:26 PM
I don't understand. There is no oil in an opti to leak out.
The o-rings on the opti shaft are not oil seals. Perhaps the timing cover seal is leaking.
Pyro97's Avatar
mines doing the same thing. I don't feel like trying to fix it and making things worse so I'm taking the "I don't give a ****" approach
maybe the crank seal?
Old Nov 13, 2006 | 11:47 PM
playa7970's Avatar
oops lol i should have reworded it, even i know theres no oil in a optii, what i meant its leaking around it, is that seal easy to replace
Old Nov 13, 2006 | 11:52 PM
droptop z's Avatar
Yeah, it's easy to replace, just a PITA to get to it. I just did mine last week.
Old Nov 14, 2006 | 02:27 AM
blown383's Avatar
Just take off the cover and replace the seal. Not hard it all.
-B
Old Nov 14, 2006 | 05:44 AM
Mtrhds94Z's Avatar
Or leave the timing cover on, and replace it... even easier..
rjc1629
Jan 27, 2015 10:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
squarehead
Nov 21, 2014 08:02 PM
omarECD
Aug 19, 2002 07:28 AM
