275 hp vs 285 hp stock
Old Jul 14, 2005 | 02:26 AM
pHEnomIC's Avatar
Do the dual cat cars really have 10 extra hp stock and is this shown at all at the ground on the dyno? Always was curious about this. And also, it is the dual cats that gives this improvement, right?
Old Jul 14, 2005 | 06:15 AM
METALBEAST's Avatar
Re: 275 hp vs 285 hp stock
Its just a rating. Consider most LT1s 300ish FWHP cars
Old Jul 14, 2005 | 07:08 AM
Feenix's Avatar
Thank you
Old Jul 14, 2005 | 11:23 AM
salty's Avatar
I was under the impression that there was an actual difference b/t the single and double cat cars, due to better flow. I'm hoping that headers on my single cat will seem more noticeable b/c of that-Is that an unreasonable expectation? So 300 FWHP translates to what...245-255 RWHP? A bit more w/M6, I'd guess.
Old Jul 14, 2005 | 12:11 PM
multicar's Avatar
While the dual cats on the '96 up fbods are the most obvious difference, there are others items like the cam, and programming.
See http://www.9c1.com/technical/LT1_rebuild/ar99928.htm
for the cams specs.
Doug
Old Jul 14, 2005 | 02:27 PM
AlwaysCode390's Avatar
Yeah, I always though it had something to do with the programming from the obd1 and obd2 computers that gave it the extra ummmph----
Old Jul 14, 2005 | 07:39 PM
salty's Avatar
Why would they have switched from 1 cat to 2 if no power gain? Perhaps meeting emissions standards-I'd be curious to know...
Old Jul 14, 2005 | 08:09 PM
indieaz's Avatar
Dual cats are necessary for OBD-II so you can tell WHICH bank is running lean/rich. All cars had to be OBD-II by '96 model year. The reason for going to dual cats in '95 i believe had something to do with California emissions requirements???
Old Jul 14, 2005 | 09:39 PM
salty's Avatar
Never thought about that. Does that mean my car won't throw separate codes distinguishing which bank is running improperly? Do the post cat O2's on the 2 cat cars make that possible where my O2's will not? Sorry for so many questions, I'm just wondering.
Old Jul 14, 2005 | 10:35 PM
flatlander757's Avatar
do you mean REAR WHEEL HP? our cars arent FWD
Old Jul 14, 2005 | 10:41 PM
heitz's Avatar
he means flywheel hp
Old Jul 14, 2005 | 10:46 PM
lol, my bad
Old Jul 15, 2005 | 12:37 AM
zackz28's Avatar
The obd II & dual cats came in the last half of the 96 models all 95's are obd I & single cat. All 97's are the dual cats and obdII.
Old Jul 15, 2005 | 01:00 AM
JBird33's Avatar
Negative ghostrider, you could get a '95 dual cat in Cali - and all 96's are dual cat, everywhere.
Old Jul 15, 2005 | 01:15 AM
ss#1230's Avatar
and you know this....man!
