2400 stall with comp cam 306 too small?
Old Apr 4, 2005 | 05:29 PM
BlueLT1B4C's Avatar
Banned FOR SCAMMING - Nick[William] Dascal - (516) 931-0586
Is the B&M Tork Master 2400 converter too small for the comp cam 306?
Old Apr 4, 2005 | 05:31 PM
madwolf's Avatar
Re: 2400 stall with comp cam 306 too small?
Depends on what your goals are. For best 1/4 times, yes, it is small, otherwise it will work. I've got one with a very similar cam.
Old Apr 4, 2005 | 05:34 PM
BlueLT1B4C's Avatar
im never at the track, just on the street, so will it be good enough to wake up the cam better than stock
Old Apr 4, 2005 | 05:35 PM
madwolf's Avatar
Yes, I have no problems with it whatsoever. Good driveability and still kills the tires if needed.
Old Apr 4, 2005 | 06:49 PM
jkipp84's Avatar
I had a 2400 with my XE 224/230 and it was pretty good for the street. The only reason I got it was to deal with the higher idle (creeping @ when stopped). Did the job.
By the way - spring the extra $50ish for a trans cooler when you do the stall. Well worth it
Old Apr 4, 2005 | 07:16 PM
Antz97ZNJ's Avatar
3000 plus...my 2600 on my 97 was too mild,could only imagine a 2400...probably feel just like the stock
Old Apr 4, 2005 | 07:54 PM
96m6lt1's Avatar
man,to utilze the power of the cc306 you need atleast a 3500 stall spend the extra cash to get what you NEED.if you consult c.c. they will tell you that cam needs that or more.....
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
