230/236 install on a buget/ got ???'s
Old May 14, 2005 | 06:57 PM
street demon2k3's Avatar
i am going to install a 230/236 cam, but i am on a budget. what kind of things can i get away with installing this cam on my 146,000 mile car?
so far i am going to buy:
opti
CM gasket set
re-tune
LS1 springs
after that i am just blank, can you guys help me out a little? any help is appreciated i am going to do a search right now then i'll post back, and see what you guys have to say.
Old May 14, 2005 | 07:07 PM
resurrectedz28's Avatar
Re: 230/236 install on a buget/ got ???'s
Timing chain? I think a double roller and a electric water pump run about as much as the lt4 extreme duty, but if you already bought an opti for a 93 car...
BTW make a post about how your car does after the install, and also do you know the history of the engine or were you the only owner?
Old May 14, 2005 | 07:55 PM
as far as i know i am the third owner, but the car was just about stock except for a borla catback when i got it last year. i have talked to other guys who knew the previous owner, and they all told me the car was never ragged on. the guy just had it for show(stereo/wheels), but kept it clean and garaged. the car has never given me problems except for changing plugs and wires, and i have always changed oil just about every 3k miles.
i just searched a little so i came up with buying
springs
pushrods
timing chain(prolly a new OE unit)
opti
rockers
gasket set from CM
re-tune from PCM4Less
what do you guys think? the cam 230/236 will be installed within the next week or two by me and a few friends. aslo how long will it take to do this install properly, and any things i should watch out for while i do it? thanks again guys!
Old May 14, 2005 | 08:39 PM
streetbad's Avatar
Get a adjustable pushrod to check the length of pushrods you need to buy. Check for length on intake and exhaust on BOTH banks. Mine needed two different lengths so I had to buy 8 more push rods which ended up being more expensive than a length checking pushrod.
Old May 14, 2005 | 08:42 PM
96ta(nick)'s Avatar
Why would you need anything other than stock length unless you have head or block work done?
Old May 15, 2005 | 12:59 AM
redcamaroz28's Avatar
I just finished my install of this cam a week ago. Here is what my set up is (other mods in sig):
Springs: Comp Cam 612's $110 (combination motorsports)
Pushrods: Hardened Stock lenth $25 (combination motorsports)
Replacement timing chain $40 (GM dealership)
Because of the high mileage, i'd recommend you get new lifters as well. The cam install should take a weekend, but can be accomplished in one day.
BTW, I am VERY impressed with this cam. I have tuned out almost all of the cam surge and I have no problem with it in stop and go traffic. It pulls hard from 2500rpms.
I just dynoed it today, too: http://www.fuelslut.net/hosting/uploads/Dyno.jpg
I'm sure I will break 350hp if I get the A/F down from 14.1 to ~12.5. The first run was only up to 5900rpms, too, and it was still pulling. The second run I added too much timing (plus lean) so it was breaking up bad up top. The torque curve (more like straight line ) is what really impressed me too, with 300tq from 2600rpms to 5800rpms.
Ryan
Old May 15, 2005 | 11:44 AM
streetbad's Avatar
Because of the base circle being smaller than stock,production tolerences.and the checking pushrod only being $25.00 (maybe you could borrow one).This being done on a budget(as mine was) Better to know what is needed than "assuming". -Tim
Old May 15, 2005 | 08:36 PM
rpm4lalo's Avatar
What kind of rockers are you getting?
The Non-Self Aligning type of rockers require guideplates and hardened pushrods, and if they are 7/16 instead of 3/8 you will also need 7/16 rocker studs.
Old May 16, 2005 | 01:09 AM
i was thinking of using the original rockers, till i can buy some 1.6's. i have about $600 to spend for parts and labor. my friend is going to do the install cheap, and he said to pay for the cam later. so all i have to buy is the parts.
recamaroz28-can you post up a detailed parts list for your install with prices and everything. or just PM me if you want. i saw your other post, but i just wanted to get everything together before friday night, cuz saturday morning my car is going under the "KNIFE". i should get everything running by sunday night or monday morning.
if anyone wants to add anything else, just post up. i am still searching and looking around for as much info as i can.
Old May 16, 2005 | 01:26 AM
SoloExceptional's Avatar
myself I'd go with a timing chain and consider getting new retainers and locks for your springs, unless it's a complete kit :-D you might want to get you some Pacesetter LT's and port the heads while your at it... just for grins
Old May 16, 2005 | 10:33 AM
1996LT1NY's Avatar
Originally Posted by redcamaroz28
I
Ryan
This is with stock heads? I'd be pretty happy with it too
Old May 16, 2005 | 02:06 PM
RealQuick's Avatar
new lifters...
Old May 17, 2005 | 03:09 AM
street demon2k3- Here's what all I went with:
Gaskets: Intake $15-20 Timing cover (can't remember) Discount auto
Cam: XE 230/236 $260 shipped (Thunder Racing)
I already had 1.6 rockers as well as new lifters. (4 months ago I blew a head gasket and put these in while I was already in there ) New lifter I think cost around $220 (stock replacements are fine, but you can go with COMP R's for a little more $) and 1.6 rockers are from $160-350.
NOTE: BE CAREFULL not to rip the pan gasket around the timing cover. Take your time and have a friend help you while doing this. Unbolt all pan bolts except the two in the very back. If you rip the pan gasket, that'll be $30 (ask me how I know ). Good luck with the install and feel free to PM me if you have any questions or problems with the install.
Ryan
Old May 17, 2005 | 09:28 AM
SStrokerAce's Avatar
http://web.camaross.com/forums/showthread.php?t=367150
Might want to read that thread as well..... Just some things to think about.
Bret
Old May 17, 2005 | 09:59 AM
REDcamaro- everything you got, i ordered yesterday from Dave at CMS. he was quite helpful too. Dave told me i should replace the lifters since my car has 145k miles on it, but i dont know if i can get away with it. also i am going to use my original rockers till i can get a deal on some used ones from a local board member. one last thing, how many miles are on your car?
SStrokerAce- didnt see your post there yesterday, but it was very intresting. good stuff too, very informative.
