224/233-536/555-114 Comp Cams For Lt1????
Old Oct 23, 2006 | 12:25 AM
camarohg's Avatar
hi my question is what part # this comp cam has? because somebody selled on ebay a camshaft and he said that this cam is better than the hotcam.
The kit will come with a Comp Cam Custom Grind .224 .236 .536 .555 LSA 114 small base circle. The cam was used in a 383 application, and what comp cam is it for a lt1, the item number in ebay of the kit is 270040897843, so please if you know the part number of this cam write me bye
Old Oct 23, 2006 | 09:22 AM
Ray@NitroDaves's Avatar
Re: 224/233-536/555-114 Comp Cams For Lt1????
The kit will come with a Comp Cam *****Custom Grind****** .224 .236 .536 .555 LSA 114 small base circle. The cam was used in a 383 application, and what comp cam is it for a lt1, the item number in ebay of the kit is 270040897843, so please if you know the part number of this cam write me bye
The cam is a custom grind it will not be in the catalog
Old Oct 23, 2006 | 10:51 AM
seawolf06's Avatar
You need to get the lobe numbers because that is not a Comp grind, it's a custom grind. Just remember, bigger isn't always better when talking about cams. Check out the CC305, CC503 and GM 846 since they're all in that duration range. Good luck.
oldschool
Feb 9, 2016 09:21 PM
alliance12364
Mar 6, 2015 04:39 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Elcojoe
Nov 17, 2014 10:27 PM
Wicked
Jul 25, 2002 04:19 PM
