224/230 Xe
224/230 Xe
I've looked for this answer but can't find it. I'm doing the 224/230 cam install after reading alot of posts recommending it with stock heads. I've heard i should upgrade my injectors and fuel pump. Are the stock 26 lbs injectors good enough? I already got all the valvetrain stuff, still need the gaskets, I just want to make sure I do this right and once.
Re: 224/230 Xe
Ditto, 94-97 cars all got 24 lb/hr injectors (93s got 22 lbers). I thinkt he general consensus is that the 24 lbers are good for up to 400 rwhp on an N/A engine. You shouldn't be making that much without headwork and that cam.
Re: 224/230 Xe
I probably saw duty cycles of around 65% or so with 30# injectors and that cam. Now with heads I see about 85% at about 5500 rpm. It would be a good idea to upgrade especially if you want to add heads in the future.
LimitedEd1LE
May 18, 2015 01:24 PM
Dave88LX
May 21, 2003 10:30 PM
Chris 96 WS6
May 17, 2003 01:12 PM
gb95zconv
Apr 23, 2003 07:48 PM
Zio
Apr 2, 2003 01:07 PM
