for a 224/230 what do i need?....(cam swap)
Old Apr 21, 2005 | 11:56 PM
SkillZ25's Avatar
ok guys i need help i think i have everything on my list but im not sure what kind ...here just let me know what u think...its on a low budget
-cc xe 224/230
-cc magnum 1.6 rr's (sa)
-751 retainers, 983 springs, 613 keepers ..will those be ok with this cam?
-cc hardened pushrods
ok i know i overlooked a timing chain set but i just got a new set (stock) like 3000 miles ago, I will do a mail order tune, and if there is anything that i dont really need please let me know my budget is as low as possible..thanks
Old Apr 21, 2005 | 11:59 PM
Compstall's Avatar
Re: for a 224/230 what do i need?....(cam swap)
Gaskets (Thunder Racing sells a cam swap gasket kit). Orange and black RTV, thread lock, and some assembly lube. There ya go, add another $100 worth to your list...
Old Apr 22, 2005 | 12:02 AM
94formulabz's Avatar
Since you are budget limited i'd skip the ARP studs and reuse your stock lifters.
-brent
Old Apr 22, 2005 | 12:06 AM
SkillZ25's Avatar
gaskets and every thing SHOULD be taken care of...the story is that a shop might have to yank my engine to get some oil pan leaks....so i might be able to slip a cam in there ...i work there...so ill be able to do it but im on low budget ya know.
how much HP will i lose if i reuse stock lifters? is there any risk of anything with stock ones? and the studs will be fine?
thanks guys
Old Apr 22, 2005 | 12:15 AM
Like 2 hp if any......
Your rocker adjustment is going to make a bigger difference in HP than the lifters.
Its a roller cam so no there is no risk with reusing the stock ones unless they are extremely high milage and were about to fail anyways. Some builders use the stock replacements for much wilder motors.
My studs are fine. I'd wager that the vast majority of ppl with cams are reusing the stock studs. Plus, if your getting new studs then DEFINITLY go 7/16 and order rockers to match.
Noone take what i'm saying that replacing that stuff isn't a good idea, i'm just saying that is is DEFINITLY not required if your on a budget. I know of many people running stock lifters and stock studs.
-brent
Old Apr 22, 2005 | 12:33 AM
SkillZ25's Avatar
-brent
ok cool, then thank you very much man.....now to see if i need to order this stuff....
o btw those springs and rods will be ok right?oh and the valve covers wont need any mods right?
Old Apr 22, 2005 | 07:43 AM
gmr speed's Avatar
Im just wondering...with a CC-503 cam with 1.6 RR the springs you have listed are not going to be enough. You might want to look into that before you buy them. Are you taking the heads off?
Old Apr 22, 2005 | 09:35 AM
I did not verify if those springs are the best for that application. I'm of the opinion that there is more to spring selection than just being able to handle the lift without bind. I'd just follow comp's recommendation on springs.
The valve covers will need to be trimmed. Many people do it with a dremmel, but then you have grindings to clean up, putting sryran wrap in there will help. If you have a pair of tin snips you can use them with no cleanup.
-brent
Old Apr 22, 2005 | 03:02 PM
SkillZ25's Avatar
are there any links to that valve cover mod u know of? it doesnt increase the chance of leaks does it? (i have a valve cover leak right now)
Old Apr 22, 2005 | 09:05 PM
SkillZ25's Avatar
nvm i just found out that the valve cover mod is for the pro mags as to where im gettin regular mags, people have installed them without modifying it
Old Apr 22, 2005 | 10:04 PM
tagz's Avatar
I'm using the 986 springs with that cam. compcams recomended and their runnin great.
As for lifters, i'm using stock lifters for the same reason, i was on a budget.
Old Apr 22, 2005 | 10:28 PM
SkillZ25's Avatar
hey tagz are u runnin 1.6's? are they roller tip or full roller?
Old Apr 22, 2005 | 10:32 PM
tagz's Avatar
i'm runnin the compcams pro magnum 1.6. they are not full roller. i guess that would make them roller tip?
Old Apr 23, 2005 | 02:40 AM
SkillZ25's Avatar
i dunno i was readin somthin and it said how the promags were full roller tockers, and the mags just had a roller tip or somthin....i guess im askin what rockers are u runnin?
Old Apr 23, 2005 | 11:12 AM
whatsup's Avatar
I have that cam and love it. I'm running the Crane 10308 double springs and 1.6 SA rr's...the ones that come with the hotcam kit. You will need a good tune with that cam as well.
tagz - is that time in your sig with the cam and headers??? I'm running 12.70's off the spray....very simular mods.
