21LB Fuel injectors on LT1 engine?
Old Sep 25, 2006 | 03:09 PM
96WhiteZ28's Avatar
I just got two intakes for a friend to blast and both had 21lb injectors on the fuel rail. Is that normal for some years of LT1? I did some searching but all I came up with was 19lb for 305 TPI, 21lb for 350 TPI, and 24lb for LT1. Any help or links with charts would be greatly appreciated.
Thanks!
Old Sep 25, 2006 | 04:25 PM
Dennis93TA's Avatar
Re: 21LB Fuel injectors on LT1 engine?
92-93 lt1 has 22lb
Old Sep 25, 2006 | 04:32 PM
96WhiteZ28's Avatar
Both were 94+ fuel rails. They had the B body (Impala, Caprice, Roadmaster, Fleetwood) Hold down for the homeplate silencer... did those cars come with 21lb?
Old Sep 25, 2006 | 04:37 PM
WS Sick's Avatar
I do believe the TPI 350 cars had 22# injectors on them. What color are they?
Old Sep 25, 2006 | 04:38 PM
96WhiteZ28's Avatar
Both were 94+ fuel rails. They had the B body (Impala, Caprice, Roadmaster, Fleetwood) Hold down for the homeplate silencer... did those cars come with 21lb (21.9lb according to a site it was 19.9lb, 21.9lb, 24.9lb)?
Old Sep 25, 2006 | 05:07 PM
96WhiteZ28's Avatar
They are just black. The o rings were half black half brown one set. The other set I don't remember.
Old Sep 25, 2006 | 05:10 PM
sbs's Avatar
sbs
L99 maybe?
Old Sep 25, 2006 | 05:26 PM
Dave89IROC's Avatar
Originally Posted by steve9899
L99 maybe?
possibly
Old Sep 25, 2006 | 06:19 PM
96WhiteZ28's Avatar
L99 came with the LT1 style intake, fuel rails, and throttle body?
Old Sep 25, 2006 | 06:40 PM
96capricemgr's Avatar
The L99 got 19lbs, the b-body LT1 got 24lbs.
Yes the L99 was very much the same as the LT1 externally you need to look at casting numbers to distinguish.
Old Sep 25, 2006 | 07:07 PM
96WhiteZ28's Avatar
So these 21lbers are still a mystery lol
Thanks for all the input guys I learned a little today :-)
Old Sep 25, 2006 | 09:03 PM
What makes you say they are 21lbs? If you are referencing a PN maybe the reference you are using is wrong?????????????
Old Sep 25, 2006 | 09:27 PM
96WhiteZ28's Avatar
Good point... I know have conflicting data... one site says... Part #17121068 is 21lb flowing 220cc http://users.erols.com/srweiss/tableifc.htm. One site says 24lb flowing 256cc http://www.witchhunter.com/FlowDataPix/rp17121068.jpg
Who to believe lol?
Old Sep 25, 2006 | 09:29 PM
96WhiteZ28's Avatar
The other one that I had is #17106772
I don't know which size it is I can't find any reference to it.
Old Sep 25, 2006 | 09:34 PM
96WhiteZ28's Avatar
http://www.thirdgen.org/techboard/tp...light=17106772
Some TPI injector classifications. 17106772 is 93 GM 3.8L. How much they flowed it doesn't show :-(
