2 quick questions
2 quick questions
1. I am installing a CSR Electric Waterpump. Does the drive gear remain for the old pump remain?
2. I am installing 1.6 RR's. My mechanic tells me the stock Valve Covers will not fit, why is this? I've read the stock valve covers should be fine.
I have a 1993 Z28, a little different from the others.
Thank you.
Thank you.
Re: 2 quick questions
Originally Posted by LT1-Z
you should be fine but if not then just get tall valve covers. i say the mechanic is full of it.
I'm wondering if there is something different about the 93's that 1.6RRs won't fit or maybe he feels there isn't enough room b/c it's really tight and not he isn't familiar with LT-1s?
If I get new valve covers, how will I know what will fit the LT-1 and the 1.6RRs?
Ok, I've found that I need to snip the webbing that hold the bolt "tubes" (webbing closest to the intake)
Anybody familiar with the CSR water pump question?
Originally Posted by joeSS97
^ you are right,my bad...the timing cover has to come off.Do a searh for CSI install...you will find a guide by Ken Lawrence.
Check out this thread. There's a link with pics on how to nod the valve covers.http://web.camaross.com/forums/showthread.php?t=377781
Jan 23, 2015 01:13 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
