2 Issues, Smoothness, RPMS dropping
Old Oct 4, 2005 | 12:43 PM
CColtManM's Avatar
Question 2 Issues, Smoothness, RPMS dropping
One, after extensive modding, i found my car to be smoother then i thought it was going to be. This is great sense i still like to take it out for "dates" and not have my passenger get nauseus. However, it still is a little rumbly, and i would like to smooth it out, any suggestions on how to do that?
And second, almost every time i brake to a full stop, wheter a light, or stop sign, my rpms drop and my car gets close to dieing out. This also happens when going in reverse and making quick shifts from reverse to drive and back again. My RPMS stay around 900-1200 when idle or neutral, but drop down to 400-600 during a brake or reversing. Any ideas on why, and how do i eliminate that?
Old Oct 4, 2005 | 12:44 PM
JakeRobb's Avatar
Super Moderator
Re: 2 Issues, Smoothness, RPMS dropping
Someone who knows more about automatic transmissions should chime in here, but I'm guessing that this is a great excuse to upgrade your torque converter.
Old Oct 6, 2005 | 09:59 AM
CColtManM's Avatar
Exclamation Re: 2 Issues, Smoothness, RPMS dropping
One more thing to add to this, when i am at idle, after my rpms drop a little, my oil pressure is somewhat sparatic at times.
Old Oct 6, 2005 | 10:25 AM
Mean Green's Avatar
sorry to say, but you're not going to smooth out much. the LT4 hot cam, although it is pretty tame for what it is, you're still going to have that little lump in the idle. you could try redoing all your bushings in the suspension. the worn out bushings will cause some of a harsh ride, but the camaro is inheirently stiff and you'll feel almost every bump.
jackpawt883
Feb 26, 2015 09:04 PM
DetroitZ28
Feb 13, 2015 07:33 AM
Alex Barnes
Jan 24, 2015 10:21 PM
97SSdude
Dec 31, 2014 07:43 PM
mattszm6
Dec 14, 2014 07:09 AM
